Column Lock issues
Old Aug 17, 2010 | 04:37 PM
muelledc's Avatar
muelledc
Default Column Lock issues
Guys,
I wanted to make sure that I have done everything I can. My column locked about a week ago. Since then I have bought and installed the column lock bypass. The bypass unlocked the column lock, but I am still getting the service column lock message and the pull key, wait ten seconds message error message. The fuel shuts off when I try and move the car. To fix this I have pulled fuse #25 and disconnected the battery. I am getting the battery tested tonight.
If the battery is strong, is my only other option to get HPTuner software and set the fuel cut off to a high MPH? I would rather deal with the source of the service column lock error rather than just do the work around.
Any ideas?
Thanks,
Duane
Old Aug 18, 2010 | 02:18 AM
muelledc's Avatar
muelledc
Default Update
Car is 03 Zo6 manual.
I had the battery tested, it was weak and 12.0volts across the terminals. I will charge it tomorrow night and post the results.
