Service Traction Control/Active Handling?
Service Traction Control/Active handling came up on the display, so did the traction control "off" light on the dash. I back out of the drive, went down the street a bit, pulled to the side, shut the car down for a few seconds, restart, all warning disappeared.
What the heck was that about? Anyone experience this before?
with the key in the on position, but the engine not running
push and release the reset button until all messages cleared
next push and HOLD button #4
next push and release button #1 four times while holding button #4
When first engaged the on-board diagnostics go into an "automatic" mode which shows all parameters: PCM-TCS-RTD-BCM-IPC-radio-HVAC-LDCM-RDCM-SCM-RFA. If there are no problems, you will see "no more codes" on the ICP display. The computer will show two kinds of codes, "current" and "history," designated "C" or "H". A current code indicates a malfunction is present in the system whose module is displaying data. A history code indicates a past problem. When the screen displays "manual diagnostics," select the desired module by pressing the "options" button to go forward or the "trip" button to go back. Press "gages" to go forward or "fuel" to go back. To exit the diagnostic mode at any time, press "E/M".
you can erase or "clear" codes by pressing "reset"
Mic
