Replacing a front wheel stud
Old Aug 19, 2010 | 10:52 AM
Overdrive's Avatar
Overdrive
Default Replacing a front wheel stud
Have a broken stud on the front of a 99 Vette. I've knocked out the old stud and have a new one to put in.
Can you get the stud in without removing the hub from the spindle?
Old Aug 19, 2010 | 11:03 AM
japc5's Avatar
japc5
The service manual says to remove the wheel hub.
Old Aug 19, 2010 | 11:14 AM
Overdrive's Avatar
Overdrive
Thanks, that's what I was afraid of. Doesn't seem to be a spot where you can slide the stud straight in.
alextz's Avatar
alextz
You can remove without having to take the hub off. There is one position where you can get it out. So, take hammer, whack the stud you want removed till it comes loose, then rotate the hub until you get to that one place where you can pull the stud out.
the rears, though, you do have to take the hub off (although some people cut and drill to enable doing it without taking hub off).
Alex
Old Aug 19, 2010 | 11:19 AM
Overdrive's Avatar
Overdrive
Alex
I have the broken one out as it was a lot shorter. I'll try removing the caliper to see if I can find a spot to slip it in. Removing the hub is the last resort as this means dropping the lower ball joint to get room to remove the lower hub bolt.
Old Aug 19, 2010 | 01:05 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Remove caliper, caliper bridge and rotor to give your self some working room. There is definitely a spot that the new full length stud will slip in without removing the hub. Once you have it in, use a stack of several washers and a spare lug nut to sinch it down tight. Make sure that the stud is fully seated against the hub before reassembling.
Old Aug 19, 2010 | 01:30 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I even managed to get longer studs installed without removing the hub...
Old Aug 19, 2010 | 01:49 PM
Overdrive's Avatar
Overdrive
Thanks I'll try it and see if I can get the new stud in.
To Replacing a front wheel stud
