Bad Vibration in Driveline????
Old Aug 20, 2010 | 05:38 PM
happa's Avatar
happa
Default Bad Vibration in Driveline????
I have this bad vibration while im driving. There is no whine from the rear, well at least I dont hear one. My Vette is very loud. I noticed the vibration when I put the C6 Z51 sways on. and I just installed the PFADT rear tranny brace and it seems worse. The tranny shifts fine, the clutch feels normal, and there isnt any kind of noise. Im kinda leaning toward the bushings in my torque tube.My vette has 86k miles on it and read sig for my mods. Please let me know any information or ideas. Thanks in advanced!
Bryan
Old Aug 20, 2010 | 11:04 PM
knapptime's Avatar
knapptime
if you figure it out let me know. i also have a vibration. i rebuilt my torque tube didn't help
Old Aug 20, 2010 | 11:42 PM
happa's Avatar
happa
I will man, I looked at my engine mounts and they look good, and visually looked at everything and couldnt see anything. But Im hoping its not the rear diff or torque tube bushings. This coming Feb. I was going to buy a rear diff. Maybe it can stay together till then
Bryan
Old Aug 21, 2010 | 07:07 AM
WKMCD's Avatar
WKMCD
I had the PFADT tranny brace in my car for less than 50 miles. It will transmit EVERY bit of vibration that may be in the drive train. I had no noticable vib's before or after.
There are a lot of people who took it back off because of the vibration.
Old Aug 21, 2010 | 01:28 PM
happa's Avatar
happa
Thats good news. It seems to kinda go away if im driving it and I press the clutch in. Its weird. I just hope I dont break anything before I can have the time to put a rear diff in.
Bryan
Old Aug 21, 2010 | 07:28 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Bryan,
At what rpm's does it seem the worst? Can you get the vibration with the car parked,trans in netrual, clutch fully up (engaged) by slowly rev'ng? If you do, what rpm does it start and does it peak and then get less as you go higher?
Old Aug 22, 2010 | 12:15 PM
happa's Avatar
happa
Originally Posted by Eric D
Bryan,
between 2k and 3k it is worse. Im not sure about the vib. at idle, i have a big cam that shakes the car, when i engage the the clutch it seems to go away some. I havent tried it with rev'ing it.it peaks aroun 3k and goes away at any rpms after that.....
Bryan
Old Aug 22, 2010 | 12:20 PM
Eric D's Avatar
Eric D
Bryan
Try the rev in neutral and one more important question, where do you feel the vibration? Steering wheel, seat, floor, shifter, etc..
Old Aug 22, 2010 | 04:30 PM
happa's Avatar
happa
Ok, i'll try that. I feel it in the drive train, if vibrates the whole car while im driving.
Old Aug 22, 2010 | 08:37 PM
Eric D's Avatar
Eric D
The next time you are in your car see if you are feeling the vibration more from one place than another. This bit if infromation can be helpful to identifiy the source.
Old Aug 23, 2010 | 11:26 AM
DIYdreamcar's Avatar
DIYdreamcar
Not saying that I am having a vibration around 2k or anything
-Ed
Old Aug 23, 2010 | 08:20 PM
happa's Avatar
happa
I kinda feel it in the drive line when I rev it up. I drove it around today and it didnt seem as bad, either Im getting used to it or whatever wrong is about to come apart!
Bryan
Old Aug 23, 2010 | 09:03 PM
Eric D's Avatar
Eric D
Bryan
Can you explain what you mean when you say "I kinda feel it in the drive line"?
Old Aug 23, 2010 | 09:17 PM
happa's Avatar
happa
sorry, I feel it a little bit in the shifter, gas pedal, seat, steering wheel. Its not really bad at all, i can mainly tell when im driving down the road. I had to concentrate kinda hard to see if I feel it when I rev it. Also thank you very trying to help me. Im not too good at explaining things so you might have to bare with me.
Bryan
Old Aug 23, 2010 | 11:11 PM
Goody's Avatar
Goody
Bought a used Centerforce DF clutch with GM flywheel from a forum member and it vibrated at 1650-1900RPM and 3700-3900RPM. Tried an ebay F1 lightweight flywheel, same issue. Finally fixed when I switched over to a LS7 setup. Obviously the CF clutch was the culprit in my case.
Old Aug 24, 2010 | 06:50 AM
Eric D's Avatar
Eric D
Yep, clasic 1st order imbalance by the rpm points you have. Depending on how bad yours was, the 3700 - 3900rpm normally will be felt the most on the shifter. Before replacing a clutch as you did, sometimes a manual balance of the engine can correct it if you have a OEM flywheel with the balancing holes every 30 degs. It is a trial and error process if an analyzer isn't handy. Having the analyzer make the job a lot easier.
Old Aug 24, 2010 | 11:35 AM
DIYdreamcar
So theoretically at least, what could cause an imbalance in an engine/driveline which is guaranteed all original?? Excuse me, more specifically a first order imbalance??
Not trying to be a smart a**, simply trying to understand what is happening to my car
-Ed
To Bad Vibration in Driveline????
Old Aug 24, 2010 | 12:21 PM
Eric D's Avatar
Eric D
-Ed
Ed,
Here is a couple of ways to think about vibration. I will focus on 1st order imbalance, but keep in mind there are many modes of vibration besides 1st order. 1st order happens when a component has more mass on one end compared to the other about the rotation center. Just about any rotating component will have some amount of imbalance. It really isn’t an issue unless this vibration transfers to other components. The Corvette has a very unique powertrain compared to most vehicles. So, the second part of this is the transfer of vibration. The primary reasons for engine and transmission mounts that can move are to isolate powertrain vibrations from transferring into the vehicle. Designing the powertrain mounting system is a big deal. It takes a lot of work to get it right. Changing mounts to something different than stock will buy you little or nothing in performance and in most if not all cases will degrade vibration isolation.
I don’t know the detail of your vibration. You mentioned your car is stock. Do you know if your vibration is powertrain related? Just about anything that rotates could be a source, like wheels, tires, brake rotors, hubs, etc..
Old Aug 24, 2010 | 02:40 PM
DIYdreamcar
Car is completely stock save a shifter, blackwing and Ti mod exhaust. The vibration seems independent of speed, but dependent on RPM starting at around 2K and ending maybe around 2.5K. Usually felt in the pedal, kinda the seat. Really hard to know for sure, it is almost like my bat-sense is telling me it is there.
Now, on the completely stock list, I will say that I am getting some inconsistent hesitation from the motor and have plugs and wires on my to do list. I was thinking this might be part of the source, but hadn't gotten there yet. At 47K over 8 years it has not been driven a ton until recently when the AC on the normal DD died and I survive (barely sometimes) down here in Houston.
Thanks for your help
-Ed
Old Aug 24, 2010 | 03:01 PM
Eric D's Avatar
Eric D
-Ed
Ed,
If the car was fine and then all of a sudden started to have vibration issues I think you maybe on the right track looking at plugs, wires, injectors and maybe even running a compression test.
If you have an engine 1st order imbalance it will show up just rev'ng the engine with the clutch pedal pushed in. If you only get the vibration with the clutch out and the trans in neutral it could be the clutch disc, or something with the propshaft. If it only happens while rolling down the road, could be output shafts, tires or wheels.
