Headlight problem?
Old Aug 21, 2010 | 03:16 PM
thetitan's Avatar
thetitan
Default Headlight problem?
I have a 98 coupe, and on a few occasions when I turn the headlights on, they dont raise up. Then you have to turn them on-off-on and they raise up. They seem to be working fine almost all of the time, the problem only happened about 3 times so far.
I have read some other posts about similar problems with the column switch or the control module.
Which is the best approach to take???
Thanks, Gene
Old Aug 22, 2010 | 10:11 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
sounds like maybe the stops are worn and the motors are having a hard time lifting the lights because they get stuck a bit...have you tried flipping the plastic stops? Of course the switch could be an issue as well
Old Aug 22, 2010 | 10:26 AM
k0ts's Avatar
k0ts
If both headlights do the same thing I'd put my money on the switch.. You'd think
a bad stop would only affect one light.
Old Aug 23, 2010 | 03:44 AM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
humm, i'm having the same problem after replacing the gears . i turned on twilight which i was told would bypass the switch to rule out the switch. when the lights are down and won't come up and i open them manually sometimes they will come up once i start them. the other day when i started them up manually it seemed tight and when i moved it and got the tension off it popped right up. could they be going down to tight and the motor has trouble getting it started? if so how would i fix this.. the grounds seem to be ok also. this problem is about to drive me f'ing crazy.
Old Aug 23, 2010 | 08:25 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Almost always, the problem is the headlamp/multifunction switch. There is a headlamp controller mounted on the right forward frame rail behind the right headlamp. You could re-seat the connectors on it but again, the switch is probably the cause.
To Headlight problem?
