Low Oil Pressure Intermittently
Old Aug 22, 2010 | 09:06 AM
beachguy6114's Avatar
beachguy6114
Cruising
Default Low Oil Pressure Intermittently
I have a '98 with 198,000 and yesterday the oil pressure was up and down for about 5 miles of driving at 45 to 50 mph. The only other problem I have had with this car was the oil pressure sending unit which has been replaced now 3 times. I beleive it to be an issue with the oil pump. My question is, I have a lift and all the tools I need; do I need to pull the steering rake off to change out the oil pump?
Old Aug 22, 2010 | 09:11 AM
lucky131969's Avatar
lucky131969
Originally Posted by beachguy6114
.....do I need to pull the steering rake off to change out the oil pump?
Yep.
Old Aug 22, 2010 | 10:08 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Sounds to me like you are missing the most important tool....... a service manual
Old Aug 22, 2010 | 10:09 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
fix it quick or you are gonna have bigger issues
Old Aug 22, 2010 | 11:19 AM
beachguy6114
Cruising
Thanks for the input this morning. Well, my mindset is the pump needs replacement; any suggestions from the forum as to what I should purchase. The tear down starts tomorrow and looks like a rental will be needed for Carlisle this year.
Old Aug 22, 2010 | 11:33 AM
lucky131969
With that many miles, a stock pump seems like an obvious choice.
Old Aug 22, 2010 | 11:53 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
I would also suggest a new timing chain and harmonic damper if the stock ones are still in place.
Old Aug 22, 2010 | 12:05 PM
beachguy6114
Cruising
I was already going to replace the timing chain; thanks for the confirmation. But I did not consider the harmonic............looks like I'll be busy.
Old Aug 22, 2010 | 12:09 PM
lucky131969
Not anymore busy than if you just changed the pump.....it all has to come apart anyway..
To Low Oil Pressure Intermittently
