<<<<C5 Diff output shafts, let's compare the options available..........
Old Aug 22, 2010 | 11:03 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Default <<<<C5 Diff output shafts, let's compare the options available..........
I've done this swap a few times, often replacing the long shaft only
Sources:
1. Rpmtransmissions.com
2. DTE
3. Mark Williams
I believe the above are all 300M
Who else?? Is there ony a few shops making these, and some are relabeled?
4. OE GM C6Z06, I have not seen these yet, I understand they are not 300M, just a thicker version of stock c5?
I do NOT have a degree in materials science, just looking for feedback on what are the typical break items and what you have chosen to fortify your running gear in the C5
Thanks very much for the info!
Old Aug 22, 2010 | 11:23 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Steve
I just followed these two post and upgraded my differential to C6 output shafts (both long and short) DTE Bellview springs, new C6 clutches and DTE spider cross shaft.
I also have the FIRST Transzilla T60/60 T56 up-graded Transmission in the country. George at Rockland Transmissions,, ROCKS!
Here is the post that made my diff up grade happen.
- C5, Its Go Time, Output Shaft Install - Left and Right : http://forums.corvetteforum.com/c5-t...post1573404441
- C5 RAGTOPWS6, Differential UP-Grade; http://forums.corvetteforum.com/c5-g...-z06-guts.html
I also found the C5 Differential setup tool from Kent/Moore for 96 bucks!
Bill
Old Aug 22, 2010 | 10:21 PM
SteveDoten's Avatar
SteveDoten
Just installed the C6Z06 left and right output shafts today
pretty basic stuff, having a press was a must for the short side
Old Aug 22, 2010 | 10:49 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I had a friend machine out a piece of pipe that I used to fit around the cross shaft. I used the press at work. Everything went fine.
To <<<<C5 Diff output shafts, let's compare the options available..........
