Removing maxi circuit breaker
Old Aug 22, 2010 | 12:25 PM
Wade Stickels's Avatar
Wade Stickels
7th Gear
Default Removing maxi circuit breaker
Is there a trick to removing the maxi circuit breaker for the headlamp control in the fuse relay center under passenger panel? I can't seem to pull it out.
Old Aug 22, 2010 | 12:33 PM
lucky131969's Avatar
lucky131969
What are you trying to accomplish?
Old Aug 22, 2010 | 12:44 PM
Wade Stickels
7th Gear
I am replacing the Headlamp Control Module and this is the first step in the process.
Old Aug 22, 2010 | 12:45 PM
lucky131969
Why not just make it easy.....and disconnect the battery?
Old Aug 22, 2010 | 12:52 PM
Wade Stickels
7th Gear
I'll do that.
To Removing maxi circuit breaker
