6 speed trans removal help!
Old Aug 22, 2010 | 01:07 PM
Gitusum's Avatar
Gitusum
Default 6 speed trans removal help!
i am trying to pull the 6 speed trans out of a 02 coupe and i have everything loose but the rod that the shifter connects to in the trans. can it be removed without removing the torque tube? the rod is up at the top and suppose to have a pin or something in it holding the shifter rod in the trans and thats the only thing keeping me from pulling it out. any help would be great
Rick
Old Aug 22, 2010 | 01:21 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Disconnect the rod at the Shifter by loosing the clinch bolt. The rod pulls out of the tranny housing. Yes. There is a roll pin that connects the rod to the tranny and it can get tapped out with a pin punch. Once the tanny is out, remove the rod so that it is not damaged:
You can see the torx bolt in this picture:
You can "almost" see the hole in the shifter rod shaft on the tranny in this pic. Its on the top of the shaft:
Old Aug 22, 2010 | 01:29 PM
Gitusum's Avatar
Gitusum
is that the torx screw behind where the shifter goes on the rod?
Old Aug 22, 2010 | 01:32 PM
lucky131969's Avatar
lucky131969
Rick
Sounds like your working without a service manual. There are a few cautions in the procedure, that if ignored, will lead to certain damage....hopefully you are aware of them already.
Old Aug 22, 2010 | 01:34 PM
Gitusum's Avatar
Gitusum
no i am not aware of anything except i need this trans out of this wrecked vette to sell it whats the cautions?
Old Aug 22, 2010 | 01:43 PM
lucky131969
I can't seem to find my service manual right now, but if the car is already wrecked......it won't matter.
Old Aug 22, 2010 | 02:24 PM
Gitusum's Avatar
Gitusum
well the engine got pushed back so i cant get to that torx bit screw so i guess i will have to get a sawzaw
To 6 speed trans removal help!
