C5 Remove Outer Door Belt/weather strip Molding ?
XX
Can someone tell how to remove the Outer Door Belt/weather strip Molding on a c5. I know to remove the screw located on the front end but not sure what type fasteners are used. Are they push in, rivet and so on.
thanks
Kerry
thanks
Kerry
Close but maybe no cigar?
Never did the window seals, but here is a link to a C4. I bet that there is not much difference in the procedure. It should give you at least a guide to go by. Hope it helps
http://www.corvettemagazine.com/tech...dow-seals.html
XX
thanks
Post a picture
When you get the vehicle done, why not post some photos so we can all see the before and after. That is something I hope to postone for a long time if I can. Wish you well with the project.
XX
just remove the front screw then push the seal to the rear till it stops(1 inch) and then pull it towards the window,with window down. That's it...
Bossdog (04-28-2019)
XX
Nice car the way it looks. I hate to say it but I can't see the need for a paint job, but obviously there is a need.
I am glad rich goepfrich showed the proper way to remove that weatherstripping. I know somebody always knows on this forum. What great place!!
