Headlight relay
Old Aug 23, 2010 | 07:13 PM
ICUALL's Avatar
ICUALL
Default Headlight relay
Anyone got a picture showing the headlight relay location ? What is the easiest way to access it. I know it is located below the passenger headlight but where ?
Any help appreciated.
Old Aug 23, 2010 | 07:49 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Please state the issue you are having. I've not once heard of a relay failure in regards to the headlight. Usually the headlamp/multifunction switch is the cause of most headlamp issues.
Old Aug 23, 2010 | 08:26 PM
SJSZ06's Avatar
SJSZ06
There's no relay, just the controller located on the passenger side
headlight mounting bracket:
(ignore the little white square next to it, getting ready to mount an HID ballast)
The controller is completely sealed. Don't really know what all is
inside.
Old Aug 23, 2010 | 09:17 PM
ICUALL's Avatar
ICUALL
Default Thanks
Thanks guys, did not realize that the relay (controller) were the same thing. As for the issue I have a clicking sound like a relay opening and closing in that area and the battery drains within a few hours.
Old Aug 24, 2010 | 07:40 AM
dgrant3830's Avatar
dgrant3830
Then most likely you don't have an issue with the headlamps. A low battery will cause strange sounds from the headlamps. What's going on with your battery that it drains within a couple of hours?
Old Aug 24, 2010 | 10:42 AM
lucky131969's Avatar
lucky131969
Old Aug 24, 2010 | 11:14 PM
ICUALL's Avatar
ICUALL
I am wondering the same thing, it is a Brand New Sears top of the line gel. First one went dead and would not take a charge. Replaced under warrenty and this one drains in about to hours if acc is on.
Old Aug 24, 2010 | 11:18 PM
lucky131969
Originally Posted by ICUALL
......and this one drains in about to hours if acc is on.
...and why would you do that?
Old Aug 24, 2010 | 11:50 PM
ICUALL's Avatar
ICUALL
Installing new audio gear and GPS (pioneer). Have to turn on acc to do testing
Old Aug 25, 2010 | 07:15 AM
dgrant3830's Avatar
dgrant3830
The ACC powers a lot of things when its on so I'm not surprised that it'll drain pretty quickly. Put a meter across your battery with everything turned off. You need to see a minimum of 12.5vdc there for the electronics to work when considering starting the car. The starter will turn over with less but the computers won't work. Can't you just turn on the ACC when you need it, then turn it right back off? Seems the safer way to do things to me but of course I'm not in your shoes. The headlamps will make weird noises when the battery goes real low. Now unless your headlamps are coming on and staying on when they shouldn't, that's a different issue.
Old Dec 22, 2012 | 07:47 PM
mtdoragary's Avatar
mtdoragary
From: eustis FL Saved and blessed; what else matter?
I have the same problem with the ignition turned off, not ACC. Periodically my battery will drain in a few hours and as I charge it, the headlight controller will click continuously. All my grounds are cleaned and solid. I've been through three batteries this year and about to get my fourth.
Old May 18, 2014 | 02:20 PM
smglass21's Avatar
smglass21
Default 2000 c5
inside.
my retractables go up but not down,motors sound good,check everything else,you it could be a controller,everything started when my battery died and tried to start it,headlamps when up and stayed there,i have a new battery,still stays up
Old Sep 28, 2016 | 01:10 PM
gpruitt54's Avatar
gpruitt54
I have just started to have the ticking sound from the headlight control module. My headlights pop up with I turn them on but, the headlights do not retract when I turn them off. To turn them off, I have to flick the high beams on.
No issues with a draining battery.
Old Jun 15, 2019 | 09:31 PM
Steve Lovelace's Avatar
Steve Lovelace
1st Gear
Default Thanks again, I have used Corvetteforum several times to get into. Thanks again
[QUOTE=SJSZ06;1575102460]There's no relay, just the controller located on the passenger side
inside.[/QUOTE
Old Mar 10, 2025 | 11:47 AM
Zeusnut4's Avatar
Zeusnut4
Cruising
That is the relay. That's what that clicking noise is, as the guy said it above this answer, he doesn't know what's inside there!
Old Mar 10, 2025 | 11:49 AM
Zeusnut4's Avatar
Zeusnut4
Cruising
The clicking noise is the relay having a coil inside of it and that coil is not functioning fully most likely to assured of over under charging it from the alternator. Either one will cause malfunctions in the relay and cause a clicking sound. It can also be the actuator, the actuator cuz also of relay, it will also click. Clicking noise could also be stripped gears inside the headlight. That's extremely common!
Old Feb 11, 2026 | 08:35 AM
readparmstrong's Avatar
readparmstrong
My issue is not failure it is lack of voltage. I have new headlights and poor lighting. According to Kent Bash it is typical and a headlight relay connected up front on the driver's fender to the wiring to the horn can take care of the problem. Trying to connect again with Kent as he was out of relays last year.
Old Feb 13, 2026 | 05:33 AM
readparmstrong
Default Headlights
I am trying to find info on the Mad Electrician. Found the web page last year. Called and finally connected. He told me he was out of supplies and would get back to me. Last summer. He clearly knows what to do and I want to to follow his instructions . Called yesterday and will call today. Any other suggestions? I need brighter headlights and already have upgraded to Halogen. 11 volts ar headlight is the issue.
To Headlight relay
