How Does This Connector Come Off?
Old Aug 24, 2010 | 07:02 PM
ZeeOSix's Avatar
ZeeOSix
Default How Does This Connector Come Off?
How do you release the connector circled in green on the far right with the white collar around it. I'm told you push the white collar inward and pull off the connector, but can't get mine to budge. Don't want to break anything ... anyone have any experience with this one?
Seems like ever connector in the engine bay has some kind of Rubik's Cube procedure to unlocking it.
Old Aug 24, 2010 | 07:48 PM
lucky131969's Avatar
lucky131969
Rubik's cube.....
Take a small screwdriver, and push down on the white ring dead center, it will move down, and the line pulls off.
Old Aug 24, 2010 | 08:03 PM
ZeeOSix's Avatar
ZeeOSix
Originally Posted by lucky131969
Rubik's cube.....
Yeah, I was never good at Rubik's Cube ... Thanks, I give that a try.
Old Aug 24, 2010 | 08:12 PM
lucky131969
Old Aug 24, 2010 | 08:16 PM
Neil B's Avatar
Neil B
Jiggle the connector a bit while pushing on the white collar. It likes to be stubborn, but it will come free just using your fingers. Freeing up the opposite end helps too. Sounds like you're removing the intake. If you haven't removed the coolant hose to the throttlebody yet, you're in for a treat there.
Old Aug 24, 2010 | 08:29 PM
ZeeOSix's Avatar
ZeeOSix
Yep, removing the intake manifold. I actually got the throttle body coolant lines off pretty easily ... a little tricky to get the spring clamps off, and took some effort to get those 8 year old rubber lines to break loose.
Old Aug 24, 2010 | 08:31 PM
ZeeOSix's Avatar
ZeeOSix
Aaaah ... looks like the ends of the white ring pop up when the center is pushed down - thereby allowing it to slide off the nipple. Tricky little sucker ... as more than just a few connectors are under the hood. GM must have hired a bunch of old puzzle makers to design some of these connectors.
To How Does This Connector Come Off?
