Tire size
Old Aug 25, 2010 | 03:45 PM
mcviooue's Avatar
mcviooue
mcviooue
Default Tire size
Can somebody tell me what is the largest size of tire and wheels i can put on my 2000 conv. without any modification? Thanks.
Old Aug 25, 2010 | 09:28 PM
Dave68's Avatar
Dave68
You can easily run 265/40/17s in the front and 295/35/18s in the rear but keep in mind that while grip may improve, unsprung weight and rotational mass will most likely increase as well.
Old Aug 26, 2010 | 05:06 AM
mcviooue's Avatar
mcviooue
mcviooue
Hi Dave!
So with the original wheels that size of tires you are giving me would be safe? The reason I want larger if only for esthetic reasons...for the look.
Old Aug 26, 2010 | 06:46 AM
4SFED Z's Avatar
4SFED Z
You should be OK with the stockers and 295's. Go to tire site and see what is recommended
Old Aug 26, 2010 | 08:08 AM
01vetter's Avatar
01vetter
Keep in mind that you will be about 1/2" lower and your speedo will be reading somewhat high. Your car might feel a little more bouncy also.
Old Aug 26, 2010 | 09:32 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Follow this tire selection guide I made up and it will make sense...
Do it right and you will be fine with Active handling issues..
http://forums.corvetteforum.com/c5-g...ah-issues.html
Toque
To Tire size
