Long vs Short Headers
Old Aug 27, 2010 | 12:21 AM
ducatibrandon's Avatar
ducatibrandon
Default Long vs Short Headers
Ok I tried the search thing so dan't slam me to bad. What is the difference in HP if any by using long tube headers vs Short tube. I don't think it can really be a hell of a lot. Also do you guys have a problem with long tube headers hitting the ground if the car is lowered? Thanks everybody.
Old Aug 27, 2010 | 12:25 AM
lucky131969's Avatar
lucky131969
Old Aug 27, 2010 | 07:50 AM
Higgs Boson's Avatar
Higgs Boson
Depends on what you consider a hell of a lot. The headers/exhaust is not the lowest point on these cars. Longtubes will provide a MUCH bigger area under the curve (more power over a larger RPM range - which is what makes you faster) compared to shorties, which in some cases "might" peak in a similar area. Not the same.
Old Aug 27, 2010 | 08:53 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
I saw a dyno comparison of a C4 with stock, long tubes and shorties. The short tube headers did not pick up much horsepower but they did really flatten out the torque curve. I wouldn't say they are of no benefit, but if you have the option long tubes win hands down.
My car is lowered all the way on stock bolts and I have Melrose headers. I have never dragged the headers. A friend has ARH and they seem to hang lower. She has dragged them more than once. I guess it depends on the brand.
Old Aug 27, 2010 | 09:03 AM
99 vett babycar's Avatar
99 vett babycar
Ok I tried the search thing so dan't slam me to bad..
way to go !
What is the difference in HP if any by using long tube headers vs Short tube. I don't think it can really be a hell of a lot..[/QUOTE]
they make a difference. How much? if that's the only mod you're doing, not very much. If you intend to do H/C or a blower ,now or at sometime in the futur, they make a significant difference.
Also do you guys have a problem with long tube headers hitting the ground if the car is lowered? Thanks everybody.[/QUOTE]
don't know of anyone who has properly installed a set of LT headers having a "dragging" problem.If I can install my set without any issues, I figure anyone should be able to do it.
Old Aug 27, 2010 | 11:21 PM
ducatibrandon
Thanks everybody. I was thinking about some different ideas but nothing to crazy. Maybe a full system, CAI, and Wheels.
To Long vs Short Headers
