ac help
Old Aug 27, 2010 | 11:25 PM
agent1up's Avatar
agent1up
Default ac help
I just picked up my c5 from the mechanic wednesday after i took it in because of the air coming out of all vents problem. they replaced the driver side temp door actuator & the driver side air flow diverter actuator. After picking up the car it now blows cold on passenger & not so on the driver side, it also seems not to be blowing the air volume from front center vent like it did before. i did the fuse 27 thing and I'm not sure it helped...i paid good $ to get this fixed ,and now i have this new issue...should the shop calibrate anything on the actuator or something? or is there something i can do on my end?
Old Aug 28, 2010 | 01:47 PM
imavettegirl's Avatar
imavettegirl
start by talking to them, nicely.
Old Aug 28, 2010 | 02:00 PM
lucky131969's Avatar
lucky131969
So you had air coming out of all the vents, which is typically caused by a broken vacuum line, and they replaced the drivers side actuator? Hmmmm..
Old Aug 28, 2010 | 02:50 PM
00Corvette's Avatar
00Corvette
Do you have any codes?
A code would tell you if it was an actuator AND an actuator WOULD cause air to blow warm on one side and cool on the other...it could also be the wrong pressure in the AC system itself(R134 high/low)
If there are no codes though my bet it what lucky said
Old Aug 28, 2010 | 08:58 PM
agent1up's Avatar
agent1up
yeah man, i had the all vent issue,it was resolved with the actuator,I had another shop identify the actuator as the problem also...if i had a vac leak,would the new actuator fail also?
Old Aug 28, 2010 | 09:05 PM
agent1up's Avatar
agent1up
I'm going to take it into the shop on Monday...he said it could be the freon or possibly a leak in the compressor..I'm not sure if they new it was the compressor and were afraid i wouldn't do the job if i saw the bill, I'm in for $930 + other stuff i had done for a total of $1600...it's frustrating putting up this $ and still have no driver ac...
Old Aug 28, 2010 | 09:19 PM
agent1up's Avatar
agent1up
they recharged it with r134, i asked him how much, he said 1.625 ,whatever that means...also on my bill there's a charge for freeon1/2 ,whatever that means...
Old Aug 28, 2010 | 10:19 PM
bighank's Avatar
bighank
Default No vacuum sounds like the problem probably battery acid on the hard lines
Had the air from all vent problem. Disintegrated vacuum lines and bad check valve.
CHECK PURPLE CONNECTOR AT TUBING SWITCH UNDER PASSANGER SIDE OF THE DASH.
Old Aug 28, 2010 | 10:34 PM
lucky131969
Do you have auto or manual A/C?
Old Aug 28, 2010 | 11:09 PM
agent1up's Avatar
agent1up
do you have auto or manual a/c?
dual zone..
Old Aug 29, 2010 | 12:39 AM
00Corvette's Avatar
00Corvette
dual zone..
If you're getting cold air on one side and not the other, I dont' think it's the compressor. I could be wrong.
Okay, when you say 'air out of all vents'...do mean literally? I mean, was air equally coming out of the defroster 33 percent, upper vents 33 percent and lower/feet vents 33 percent? Regardless of what setting you had it on?
If you had it on HEAD ONLY. There should be ZERO air coming out of the feet vents.
Is this what you mean by air out of all vents?
Or, do you mean, cold air on one side and warm on the other?
I don't mean visible check engine light. On the right side of your gauge cluster...press and hold number 4, simultaneously press number 1 four times while holding number 4. You will enter diagnostic mode. Grab a pen and bring it with you if it's your first time.
you're looking for ANY codes in the "HVAC" section...it'll be like the 7th or 8th 'module' that will pop up.
Old Aug 29, 2010 | 12:40 AM
00Corvette's Avatar
00Corvette
and on your AC re-charge, it sounds like the guy was just telling you how much R 134a he added to your system. What is also important is what were the final high/low side pressures @ a given RPM
Old Aug 29, 2010 | 06:12 PM
lucky131969
dual zone..
Well then, I'm confused. I'm not sure I understand what the left actuator has to do with air coming out of all the vents simultaneously. Perhaps I'm a skeptic, but I bet there is a repaired vacuum line under that battery tray somewhere.
Old Aug 30, 2010 | 01:03 AM
agent1up's Avatar
agent1up
it was the temp door actuator, which had been identified as the problem by another shop...they showed me the replaced actuator that had a metal piece broken off,i have read other post on here with that exact break on that part..the all vent issue is also well posted on...
Old Aug 30, 2010 | 01:13 AM
agent1up's Avatar
agent1up
these are 2 separate issues,the all vent issue ,blows little air and the vents wont change modes...the warm driver/cold passenger is a different issue,which cant be anything from re-indexing the actuator to high side freon charge, to worst case compressor leak...i think.....
Old Aug 30, 2010 | 01:25 AM
00Corvette's Avatar
00Corvette
if you have both issues it sounds like you know the fix and the order to go in
Old Aug 30, 2010 | 09:22 AM
lucky131969
Yep, sounds like he has it all figured out..
To ac help
Old Aug 30, 2010 | 10:26 AM
agent1up's Avatar
agent1up
i don't have it figures out, these are just possibilities...but we know that its not the vac line...any other suggestions?
Old Aug 30, 2010 | 10:27 AM
agent1up's Avatar
agent1up
what are you saying?
Old Aug 30, 2010 | 10:35 AM
lucky131969
Nope, good luck with your issue.
