Factory alarm question.
Old Aug 29, 2010 | 08:23 PM
RED UFO's Avatar
RED UFO
Default Factory alarm question.
I have only owned my C5 for a couple of months so I am still learning about it. When I use the remote to lock the doors I push it twice. I am expecting to hear a beep. I get no beep. Is this normal? If it isnt where should I look for the problem?
I do not have a FSM yet.
Old Aug 29, 2010 | 09:30 PM
00Corvette's Avatar
00Corvette
Hey bud,
Press the options button on your car and you can adjust whether or not you'd like the horn to beep/lights to flash etc.. You press it and wait a second, then press it and scroll through. I'm pretty sure that the "reset" button is the one that turns it "on/off".
Old Aug 29, 2010 | 09:34 PM
jrose7004's Avatar
jrose7004
You have to program it to do that.
Old Aug 29, 2010 | 10:45 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Perhaps this will help (from 2000 owner's manual, but should apply to your 1999):
Arming the System
Use one of the two following items listed here to arm
the system:
 Press the LOCK button on the remote keyless
entry transmitter.
 Open the door. (The SECURITY light should flash.)
Lock the door with the power door lock switch.
The SECURITY light will stop flashing and stay on.
Close the door. The SECURITY light should go off.
Testing the Alarm
Use the following to test the system:
1. Make sure the hatch/trunk lid is latched.
2. Lower a window on the door.
3. Manually arm the system.
4. Close the doors and wait 15 seconds.
5. Reach through the open window and manually
unlock the driver’s door.
6. Open the door. The alarm should sound.
7. Turn off the alarm.
If the alarm is inoperative, check to see if the horn
works. If not, check the horn fuse. See “Fuses and
Circuit Breakers” in the Index. If the horn works, but the
alarm doesn’t go off, see your dealer.
Disarming the System
Always use your key or the remote keyless entry
transmitter to unlock a door. Unlocking a door any other
way will set off the alarm. If your alarm sounds,
listed below are the ways you can disarm it:
 Unlock the driver’s door with your key.
 Put the key in the ignition.
 Press the UNLOCK button on the remote keyless
entry transmitter.
Now, if a door or the hatch/trunk lid is opened without
the key or the remote keyless entry transmitter, the
alarm will go off. Your horn will sound for two minutes,
then it will go off to save battery power. And, your
vehicle won’t start.
The theft-deterrent system won’t arm if you lock the
driver’s door with a key, the manual door lock, or if you
use the power door lock after the doors are closed.
If your passenger stays in the vehicle when you leave
with the keys, have the passenger lock the vehicle after
the doors are closed. This way the alarm won’t arm,
and your passenger won’t set it off.
and from the DIC information within the owner's manual:
Lock and Arm
Press the OPTIONS button until LOCK & ARM
appears on the display, then use the RESET button to
page through the following selections:
 LOCK & ARM - OFF
 LOCK & ARM - HORN ONLY
 LOCK & ARM - LIGHTS ONLY
 LOCK & ARM - HORN & LIGHTS
If you choose LOCK & ARM - OFF, you will receive
no security feedback when locking or unlocking
your vehicle.
If you choose LOCK & ARM - HORN ONLY, only the
horn will chirp to let you know when your alarm system
has armed when locking your vehicle.
If you choose LOCK & ARM - LIGHTS ONLY,
only your exterior lamps will flash to let you know
when your alarm system has armed when locking
your vehicle.
If you choose LOCK & ARM - HORN & LIGHTS,
the horn will chirp and the exterior lamps will flash
briefly to let you know the system has armed when
Alarm
Press the OPTIONS button until ALARM appears on
the display, then use the RESET button to page through
 ALARM-HORN
 ALARM HORN & LIGHTS
If you choose ALARM-HORN, the horn will sound
during an alarm.
If you choose ALARM HORN & LIGHTS, the horn
will sound and the interior and exterior lamps will flash
during an alarm.
Old Aug 30, 2010 | 06:20 AM
RED UFO's Avatar
RED UFO
Thank you.
Old Aug 30, 2010 | 12:16 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You can go the Corvette Action Center on line and down load the PDF version of your year C5 Owners manual for FREE>
http://www.corvetteactioncenter.com/tech/index.html
I have thr PDF for 2002. Its the same as yours) PM Me your e-maol address and I will send it to you.
BC
Old Aug 30, 2010 | 12:29 PM
lucky131969's Avatar
lucky131969
BC
GMPartshouse as well.
http://www.gmpartshouse.com/download...03corvette.pdf
Old Aug 30, 2010 | 01:54 PM
RED UFO's Avatar
RED UFO
BC
Thank you
I have the owners manual. I don't have the Factory Service Manual yet. I do have the FSM for my 91. I plan to buy the 2003 FSM the funds are there.
Old Aug 30, 2010 | 01:57 PM
RED UFO's Avatar
RED UFO
Originally Posted by lucky131969
Thanks,
I will put this PDF on my computer for quick reference.
Old Aug 30, 2010 | 02:17 PM
lucky131969
Thank you
The owners manual would have answered your original question.....
Old Aug 30, 2010 | 03:26 PM
RED UFO's Avatar
RED UFO
Point taken.
It just never accurred to me that it would be a selectable feature.
Old Aug 30, 2010 | 03:52 PM
00Corvette's Avatar
00Corvette
Point taken.
It's cool man, you said you've only had the car for a couple weeks. Most cars don't have anywhere near the features of a C5 as far as the DIC goes.
The DIC is your little driver information center there below your speedo/tach that lets you adjust all that crap.
Another cool thing that I don't think you'll find in the owners manual.
Press and hold number 4 on the right of the instrument cluster, simultaneously press number 1 four times while holding number 4. You will enter diagnostic mode. This is basically meaning that you can check and see what the problem is any time there is a trouble code/check engine light on in your car.
Old Aug 30, 2010 | 04:15 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You don't need the service manual to set up the memory and IPC functions. There in there but,,,,, the owners manual is your friend in this case. Have you considered the ELECTRONIC version of the service manual?
Its a DVD/on line service manual that covers ALL GM from 1995 to 2005.
There are a couple of people on the forum and on line that sell them and there very reasonable
Old Aug 30, 2010 | 04:16 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
This might help understand the DTC and code reading:
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Aug 30, 2010 | 04:46 PM
markKlein's Avatar
markKlein
Friendly suggestion, read the owners manual cover to cover. There is a lot of good information in there.
Old Aug 30, 2010 | 05:39 PM
BitViper's Avatar
BitViper
Where is the alarm.... is ther a way ioto adjust the sensitivity?
Old Aug 30, 2010 | 05:47 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The alarm system consist of the following components:
Horns
Door, trunk switches
BCM
Theft deterrent ignition system
Theres NOT anything to adjust other than what will honk, flash or blink light wise when the alarm sounds. If you open a door or the trunk or cause something to wake the BCM from the sleep mode IE drawing current to turn on something) the alarm will sound if you have it enabled in the options.
The ONLY thing that it doesn't have is a shock or sonic sensor but, there are companies that can add that ability to our C5 system.
BC
To Factory alarm question.
Old Aug 31, 2010 | 11:08 AM
BitViper's Avatar
BitViper
Horns
BCM
BC
Thanks Bill.. I was assumming that it was like the F-Body Alarm system...
Old Sep 2, 2013 | 04:11 PM
Corvette Maniac's Avatar
Corvette Maniac
I know this is an older topic, but is it possible that I don't have the ALARM option in the DIC?? And I can't select horn & lights for locking/unlocking :S
Is it possible the previous owner or dealer turned the alarm off?? If I open the hatch or door, the horn sounds tho... Very strange to me... :S
Old Sep 2, 2013 | 06:29 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The alarm is not an OPTION and it can not be disabled. Its part of the BCM and you can interface how it alerts" Lights/ Horn/ LIGHTS and HORN".
Even if you turn everything OFF, the security system will still disable the car.
4 OPTIONS
This button allows you to choose personal options that
may be available on your vehicle, depending on the options
your vehicle is equipped with. Some of these functions
work along with the remote keyless entry transmitter.
When returning to the options menu, the first item of the
options list will always be displayed, not the one you
were last in when you changed buttons.
The following are the options listed under the
OPTIONS button:
Twilight (Optional in United States,
Standard in Canada)
Press the OPTIONS button until TWILIGHT - OFF
 TWILIGHT - ON
 TWILIGHT - OFF
If you choose TWILIGHT - ON, press the OPTIONS
button again to display DELAY TIME 1 2 in the DIC.
Use the OPTIONS button to switch between delay time
1 and 2. You can increase the delay time by pressing
button 1 (1 FUEL) or decrease the time by pressing
button 2 (2 GAGES). Each bar is equal to 12 seconds.
Lock and Arm
 LOCK & ARM - OFF
receive no security feedback when locking or
unlocking your vehicle.
only the horn will chirp to let you know when your
alarm system has armed when locking your vehicle.
your vehicle.
Alarm
 ALARM-HORN
 ALARM HORN & LIGHTS
during an alarm.
during an alarm.
Approach Lights
Press the OPTIONS button until APPROACH LIGHTS
page through the following choices:
 APPROACH LIGHTS ON
 APPROACH LIGHTS OFF
If you choose APPROACH LIGHTS ON, the fog lamps,
front turn signal, rear back-up and courtesy lamps will
come on for 30 seconds when you press UNLOCK on
the remote keyless entry transmitter. This will occur
only when it is dark outside.
APPROACH LIGHTS OFF turns off this option.
See “Remote Keyless Entry (RKE) System” in the
Index for more information.
Auto Lock
Press the OPTIONS button until AUTO LOCK appears
on the display, then use the RESET button to page
 AUTO LOCK ON
 AUTO LOCK OFF
If you choose AUTO LOCK ON, both doors will
automatically lock when the vehicle exceeds 10 mph
(16 km/h) in a manual transmission. In a vehicle with
an automatic transmission, both doors will automatically
lock when you move the shift lever out of PARK (P).
Choose AUTO LOCK OFF to turn this option off.
Auto Unlock
The AUTO UNLOCK will be available only if
AUTO LOCK is set to ON as described previously.
Press the OPTIONS button until AUTO UNLOCK
to page through the following choices:
 AUTO UNLOCK DRIVER
 AUTO UNLOCK BOTH
 AUTO UNLOCK OFF
If you choose AUTO UNLOCK DRIVER, the driver’s
door will automatically unlock when you turn the
vehicle off and pull the key out of the ignition.
Choose AUTO UNLOCK BOTH, and both doors will
automatically unlock when you turn the vehicle off and
AUTO UNLOCK OFF turns off this option.
Here is a test to make sure that it is working properly:
Content Theft Deterrent (CTD) Alarm Mode Inoperative
Theft Deterrent System Inoperative Step
Action
Value(s)
Yes
No
DEFINITION: The theft deterrent system will not ARM or DISARM properly.
1
Were you sent here from the Theft Deterrent Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Theft Deterrent
2
Turn OFF the ignition switch.
Open the driver or passenger door.
Press the driver or passenger power door lock switch.
Close both the driver and passenger doors (Theft Deterrent System is now ARMED).
Does the Theft Deterrent system ARM properly?
Go to Step 3
Go to Step 6
3
Disarm the theft deterrent system by Inserting the door key into the driver door lock cylinder and rotate it to the unlock position, then try the passenger door lock cylinder.
Does the theft deterrent system DISARM properly from both doors?
Go to Step 8
Go to Step 4
4
Disarm the theft deterrent system by pressing the UNLOCK button in the remote transmitter or by walking into range with the passive switch ON.
Does the theft deterrent system DISARM properly?
Go to DCM Diagnostic System Check
Go to Step 5
5
Using a scan tool, try to establish communications with the BCM, LDCM, RDCM, and RFA systems.
Can the scan tool communicate with the BCM, LDCM, RDCM, and RFA systems?
Go to Step 9
Go to Step 7
6
Close the driver and passenger doors.
Press the LOCK button on the remote transmitter or walk out of range with the passive switch ON.
Does the theft deterrent system ARM properly?
Go to Step 5
7
Repair the no communication malfunction to the system that could not communicate with the scan tool. Refer to the appropriate Diagnostic System Check that applies to that system.
Is the repair complete?
Go to Step 10
8
Inspect the following circuits for an intermittent malfunction
Driver door ajar switch
Passenger door ajar switch.
Intermittent communications between the BCM, RDCM, LDCM, or RFA systems.
Power door lock switches.
Door lock cylinder switches.
Hatch/trunk ajar switch.
Hood ajar switch (export only).
Was a problem found and repaired?
Go to Step 10
System OK
9
Replace the BCM. Refer to Body Control Module Replacement .
Program the BCM. Refer to Body Control Module (BCM) Programming/RPO Configuration .
Is the replacement complete?
Go to Step 10
10
Reconnect or install any connectors or components that were disconnected or removed.
Turn ON the ignition switch.
System OK
Document ID# 221845
1998 Chevrolet/Geo Corvette
