Brake fluid capacity?
Old Sep 2, 2010 | 09:13 AM
spdislife's Avatar
spdislife
Default Brake fluid capacity?
I'll be flushing the brake system tonight with Motul fluid and I'm curious what the approximate capacity of the system is. Thanx in advance.
Old Sep 2, 2010 | 09:23 AM
bumble-z's Avatar
bumble-z
I'd have 4 or 5 , 12 oz bottles on hand. You could allways take back any un opened containers.
Are you going to be using a Motive power bleeder? They sure make things a lot easier. Good luck.
Old Sep 2, 2010 | 09:33 AM
spdislife's Avatar
spdislife
Negative on the power bleeder, but I have installed speed bleeders to make it a 1 man operation.
Old Sep 2, 2010 | 10:34 AM
00Corvette's Avatar
00Corvette
i don't know it off the top of my head but do you have your owners manual? i'm pretty sure they are available online too if you search
Old Sep 2, 2010 | 11:33 AM
bumble-z's Avatar
bumble-z
If you or any one eles interested, I have the #'s for the Motive Power bleeder tank, bleed catch bottles, & special Master cylinder cap that has a hose w/fitting that will screw onto the tank's hose fitting.
Old Sep 3, 2010 | 01:46 AM
00Corvette's Avatar
00Corvette
I'd like to know which cap it is that your supposed to run if possible? The bleed catch bottle and bleeder tank should be universal
thank you
Old Sep 3, 2010 | 07:10 AM
bumble-z's Avatar
bumble-z
thank you
You have a PM.
Old Sep 3, 2010 | 11:13 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
I use one can of ATE to swap fluid, not sure of the amount, 1 liter?
Old Sep 4, 2010 | 09:21 AM
spdislife's Avatar
spdislife
I did the flush the other night. My guess is the same. The master cylinder holds the most, lines and calipers with new pads may be the same amount as the MC.
Old Sep 4, 2010 | 02:04 PM
Chris_B's Avatar
Chris_B
Have 3 500mL bottles on hand. You will use two for sure, but might need the third if you run into any difficulty getting the last of the air bubbles out.
Chris
Old Sep 5, 2010 | 11:09 PM
j84buick's Avatar
j84buick
4 or 5? I flushed my system the other day and it only needed two. Granted I was flushing pretty new fluid so it was hard to tell when it was coming out clean. I wonder if I left a lot in the lines?
To Brake fluid capacity?
