Timing Chain Question?
Old Sep 3, 2010 | 04:01 PM
LWSZ06's Avatar
LWSZ06
Default Timing Chain Question?
I just received a Comp Cam #7106 timing chain set for my stock 04 Z06
to install my ms3 cam. It's listed as a "LS3 58X".
I thought I was to receive a #7153 listed for an LS6, but doesn't list
the reluctor size. Will the 7106 work, or do I need to return it for
a 7153?
Thanks,
Larry
Old Sep 3, 2010 | 04:04 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
# 7153 is what I used when I put my MS3 in. I could be wrong but I'm pretty sure the 7106 will NOT work.
Old Sep 3, 2010 | 06:04 PM
LWSZ06's Avatar
LWSZ06
Finally..........got through to Comp Cams,
and was told #7106 would NOT work!
Thanks,
Larry
Old Sep 3, 2010 | 06:28 PM
0331MARINE's Avatar
0331MARINE
Thanks,
Larry
Old Sep 7, 2010 | 08:54 PM
LWSZ06's Avatar
LWSZ06
UPDATE!!
Got a message from my vendor. Say he called Comp and was
told the #7106 replaces the #7153!!
I call Comp again, this time I was told the same??
I was told if it has three
mounting bolt holes, it would work. It Does!
Larry
To Timing Chain Question?
