Blet/pulleys squeaking PITA!
Old Sep 4, 2010 | 02:23 AM
ignatkor's Avatar
ignatkor
Default Blet/pulleys squeaking PITA!
A week ago or so noticed chirping sound coming from belt/pulley area, took it to a shop, afte the mechanic diagnosed it, I ended up replacing both belts, serpentine belt tensioner and idler pulley. Drove home a few miles did not hear anything. Next couple of days the chirping sound reoccurred. I can only hear it when the car is moving and I put my foot on the accelerator, while running in park it does not seem to do it at all. Now what is really strange is when I park the car after driving it and shut it off I can still hear the squeaking going on for another 5-7 sec, slowly fading until it stops. I tried manually spinning radiator fan but it seemed fine. This squeaking sound is driving me CRAZY
Old Sep 4, 2010 | 03:31 AM
00Corvette's Avatar
00Corvette
the only thing that should be spinning to the point where you could here a 'chirp' would be your cooling fans on the front of the radiator...i mean if it's making the noise with the engine shut off and you're sure it's the same noise
Old Sep 4, 2010 | 06:06 AM
DAV162's Avatar
DAV162
Had a friend have the same problem. New pulleys and belts. Look at it and puy Gator belts on and the chirping went away. The gator belt is the best belt out there.
Old Sep 4, 2010 | 04:32 PM
GM Fan's Avatar
GM Fan
Well, I don't know about this possible chirping w/ the engine just being cut off, but if it really is something w/ the accessory drive system like normal, and If it wasn't gatorbacks you put on it, I would go ahead and just spend the $50 to swap to gatorbacks now. Keep the current new ones in the trunk for backups or something.
I went through this whole mess, changed the belts first (with Dayco premium belts), no difference. Changed the idler/tensioner pulleys on both drives, chirping briefly quit for about a week but came back the same as ever. About out of ideas I went ahead and switched to gatorbacks, which advertise they specifically can cut belt noise, and the sound has been gone for 6+ months.
But if you're sure you hear the same noise when the engine is off and nothing is spinning save maybe the fans then I'm not sure what you can check there. Guess you could disable the fans briefly and see what you get.
Old Sep 4, 2010 | 05:10 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Are you sure it is coming from the engine compartment? Could it be the heater/ac blower fan? Might try going to accessory mode on your ign switch and see if you hear the noise.
Old Sep 4, 2010 | 06:44 PM
dbaker's Avatar
dbaker
If it's not a bad belt or pulley,the belt just might be dirty/greasy.Try putting a spoonful of powder cleanser on the underside of the belt and fire it up.
It's it just grease/dirt,the dry powder will clean it off and stop the bird chirp.
\db2
Carolina
Old Sep 5, 2010 | 11:33 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
If yours is making the noise after the engine stops, it can't be the belt or pulleys etc. because the are all stopped.
When I had a problem with a chirping noise it turned out to be the harmonic balancer wobbling and only when the engine was running, but yours is a different symptom.
To Blet/pulleys squeaking PITA!
