Replaced outside ambient temp sensor. Help
Old Sep 5, 2010 | 06:40 PM
2kLS1's Avatar
2kLS1
4th Gear
Default Replaced outside ambient temp sensor. Help
Replaced the outside ambient air temperature sensor and car still thinks it is 30 degrees outside. So a/c still won't work unless you drive above 45 mph for like two minutes.
Is there a reset for the outside ambient sensor or something like that? I am truly lost.
Old Sep 5, 2010 | 07:46 PM
2kLS1's Avatar
2kLS1
4th Gear
To add to the frustration. We took the corvette for a drive after new sensor was installed. It started off at -22F, yes that is a negative. And never got above 34F and by the time we hit city streets again it was in the 15-17F range up until we parked in the driveway.
Am I missing something here? To me this seems way to complicated just to turn on the a/c when it is 90F+ out here.
Old Sep 5, 2010 | 08:12 PM
lucky131969's Avatar
lucky131969
Did you do any troubleshooting, or just change the part? How do you know the sensor was bad?
Old Sep 5, 2010 | 09:18 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Sounds like a wiring harness issue to me
Old Sep 5, 2010 | 09:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I agree!! Are you SARE that the sensor is making good connection with the connector? Did you use silicone dielectric grease (I hope NOT)
BC
Old Sep 5, 2010 | 09:52 PM
trussme's Avatar
trussme
If you have any corrosion in any of the associated connectors it will increase the resistance that the climate controls is reading.
The resistance across the two sensor wires could be almost infinity,
in that case your display would read a low temp.
Just Try removing the sensor because then the HVAC defaults to 69 degrees and will let the AC turn on.
Old Sep 6, 2010 | 07:53 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
when i removed my faulty sensor i noticed one of the wire connections broke off (rusted) to the sensor plug.
You may need a new wire pigtail harness to correct the issue.
It was 50 bux for the wire harness vs the 12 sensor
Old Sep 6, 2010 | 08:00 PM
paul82146's Avatar
paul82146
I had same problem - replaced harness & was fine after.
To Replaced outside ambient temp sensor. Help
