Transmission issues
I'm new to this group but I am glad I found it. I have a problem and I hope you guys can suggest a solution.
Not to long ago I became a proud owner of a 1998 Corvette with automatic transmission.
After driving the car for almost 2000 miles the transmission started to slip (that's how it sound and feels to me). The car drives normally in 1st and 2nd gear but it wouldn't shift to 3rd gear no matter how much I rev the engine. I took the car for a transmission oil change and when we remove the transmission oil pan I noticed some buildup on the magnet of the pan. There was very little (2 quarts maybe) oil in the pan. After the oil change the car shifted to 3rd gear a couple of times and than was back to the same as before.
Please give me some input of what has happened, what parts might be damaged and some suggestions of replacement parts for those, but better quality than OEM.
I would appreciate your wisdom in the matter.
Thank You,
Dan
Fluid was dirty, 72k but no metal. I got a 2/3 solenoid that I'll replace tomorrow.
