When I'm driving the Vette sometimes it gets stuck in fourth gear. Does anyone know what the issue is? or approx how much it will cost?
My first guess is a sticking clutch, but need more info.
Stuck as in the shifter won't budge? When you are finally able to change gears is it speed or rpm related, random?
Yes the shifter won't budge. When I'm able to change the gears everything goes back to normal. It's only the fourth gear.
I can almost guarantee it's the broken 3-4 slider key (also known as synchro key). Unfortunately you have to disassemble the transmission to replace it. Call Rodney @ RPM (forum vendor) transmissions. They will take very good care of you!
