98 C5 Remotes
Old Sep 7, 2010 | 03:55 PM
paul82146's Avatar
paul82146
Default 98 C5 Remotes
OK - had a horn problem - found a bad ground under the air bag. Everything back together fine.
Horns work great now. BUT, after I reprogrammed the remotes I cannot get the passive entry to stop working. The thingy on the remote is in the off position on both remotes. Its a PIA - How can I stop them from reseting the alarm.
Old Sep 7, 2010 | 04:22 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Could you describe the problem in a little more detail? Are you saying that if you exit the vehicle, do not lock the doors and walk away with the FOB, the alarm sets?
Old Sep 7, 2010 | 04:36 PM
paul82146's Avatar
paul82146
Yes, I go into the house - put the keys on the table - the alarm will unset or set - even walking away from it while we are out - before or after I set the alarm - or don't set the alarm. Its haunted!!!
Old Sep 7, 2010 | 04:57 PM
Mark C5's Avatar
Mark C5
Sometimes working the passive switch back and forth vigorously will clean the contact and restore function. If that doesn't work take the FOB apart and clean the contacts with contact cleaner or alcohol.
Inconsistent passive operation is also a symptom of a FOB that is getting ready to die. If the above doesn't work try replacing the battery. If you could borrow a FOB from a friend and program it for your car you could determine if the FOB is the problem.
Do the FOB's work normally other than the passive problem?
Old Sep 7, 2010 | 05:01 PM
paul82146's Avatar
paul82146
I will get new batteries tomorrow - and clean the contacts. Will let you know what happens. Thanks!!!!
Old Sep 12, 2010 | 01:26 AM
paul82146's Avatar
paul82146
Default c5 remotes
Well, cleaned remotes - New batteries - Reprogrammed both remotes - - STILL the same - Found a third remote - Programmed it - Still the same!!!!!!!!!!!!!!!!!!
Even while programming the car locks & unlocks by itself.
It is haunted!!!!!!!!!!!!!!!!!!!
Old Sep 12, 2010 | 09:18 AM
Mark C5's Avatar
Mark C5
Do your tire pressure sensors work correctly?
Old Sep 12, 2010 | 11:34 AM
paul82146's Avatar
paul82146
Default c5 remotes
No tire sensors.
Old Sep 12, 2010 | 12:55 PM
paul82146's Avatar
paul82146
ttt
Old Sep 12, 2010 | 01:39 PM
Mark C5's Avatar
Mark C5
Was the third FOB a known good FOB like from a friends car?
Old Sep 12, 2010 | 05:20 PM
paul82146's Avatar
paul82146
Default c5 remotes
Nope - extra fob from the last owner - this never was a problem until I screwed with the horn (steering wheel connections) - but everything was done properly.
To 98 C5 Remotes
