Correct T1 Installation
Old Sep 8, 2010 | 08:21 PM
n8dogg's Avatar
n8dogg
Default Correct T1 Installation
Hey,
I'm looking for some step by step instructions on the proper way to install the T1 sway bars and End Links. Mine are very noisy, and the things I have read in search are unclear.
Some say to use washers behind the brackets, some say the links should be at a 90* angle to the control arm. Some say use lithium grease, some say use silicone.
Thanks!
Old Sep 9, 2010 | 08:28 AM
n8dogg's Avatar
n8dogg
Old Dec 21, 2010 | 08:24 AM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
ttt
Old Dec 21, 2010 | 09:20 AM
AU N EGL's Avatar
AU N EGL
unloaded
ie install the sway bars first. then then adjust the end links to fit
Big washer between the sway bar and the end link so just about a 90*
either grease.
may need a four post lift, or put all four wheels up on blocks or ramps.
To Correct T1 Installation
