How much hp can a stock c5 trans hold a4.
Old 09-10-2010, 02:20 PM
mike mlodecki
Cruising
mike mlodecki's Avatar
Default How much hp can a stock c5 trans hold a4.
Basic question how much RWHP can a stock c5 a4 trans hold?
Old 09-10-2010, 02:34 PM
David426
David426's Avatar
Heat is the killer to these trannys.. My 99 c5 tranny went out at 38k with 320rwtq.. More power= more heat.. A4 is weak.. An aftermarket trans cooler will help extend life
Old 09-10-2010, 02:37 PM
dankhts
dankhts's Avatar
Apparently they can't even hold as much as a stock engine makes!! add another 125hp, and then you really have problems!!
Old 09-10-2010, 02:41 PM
mike mlodecki
Cruising
ok, well i wanna do a heads and cam package headers and exhaust. only those things. im guessing id be around 450-470 depending on cam.
So it would be a must to get a new trans? i got a 2000 t/a which made 468 rwhp w/ corrections. and has an FLT trans level 4 and that thing is a beast. so i should probably go with one of those then.
Old 09-10-2010, 02:55 PM
Bluefire
Bluefire's Avatar
Everything I have been told was ~450 hp. I'm not sure if that is rwhp or fwhp.
Old 09-10-2010, 03:40 PM
madmatt9471
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It will last as long as you desire, With:
(1)A "PROPER" transmission cooler (Bypassing the Radiator altogether)
(2) A good transmission tune (Yes they can be tuned) when done with HP Tuners on a Dyno and a competent tuner
(3) Tranny Flush and new tranny fluid changes
I held 701 RWHP on my stocker with a YANK 3200 stall for a 90,000 miles, my only problem was that I did not have a cooler then and it hit 244* on a summer day and the 3/4 gears went (That is the weakest point)
For a long time I was at 423 RWHP Naturally asperated and then went to FI (Procharger) - now I had the tranny rebuilt and it has HD parts in it and now it'll last another 90,000 miles
Get it properly tuned and a good tranny cooler and you will be set
Thanks,matt
Old 09-10-2010, 05:40 PM
02*C5
02*C5's Avatar
Like stated above you need to do proper maintenance and fluid swaps. A good cooler and add a fan to boot. also the correct stall for your cam and the correct tranny tune. I have seen many guys with A4's running 500+ rwhp as their DD and they have no issues at all.
Good luck.
Old 09-10-2010, 08:18 PM
sami85L98
sami85L98's Avatar
X2.
B20forlife (12-06-2017)
To How much hp can a stock c5 trans hold a4.
Quick Reply: How much hp can a stock c5 trans hold a4.
