Only the Tach is Not working. ???
Old Sep 11, 2010 | 01:37 AM
nfratto's Avatar
nfratto
Default Only the Tach is Not working. ???
I have an 2003 C5 Coupe. I have full lights in all of the gauges and heads up display but recently the Tach will cycle on when the car is started (goes all the way up and then goes to 0). All other gauges are working perfectly. I check grounds and all plug assemblies under the hood no corrosion. Once and awhile the tach will seem to get a signal and move for a second or so then it just goes back to no reading. The heads up display is also reading 0. Any ideas?
Old Sep 12, 2010 | 02:06 AM
nfratto's Avatar
nfratto
ttt
Old Sep 12, 2010 | 05:04 AM
ASarsano's Avatar
ASarsano
have u looked at you're ECU harness i'm pretty sure the Tac is run off the ECU
Old Jun 9, 2017 | 05:30 PM
jd86L98's Avatar
jd86L98
Did you ever fix this, I am having the same problem?
Old Dec 22, 2020 | 01:58 PM
Poobahh's Avatar
Poobahh
Navigator
same
Any luck? Same issue here
Old Dec 22, 2020 | 02:04 PM
feeder82's Avatar
feeder82
Here's a thread with the issue and fix
https://www.corvetteforum.com/forums...-pls-help.html
To Only the Tach is Not working. ???
