Burping a Radiator?
Old Sep 17, 2010 | 09:33 PM
nmbsun's Avatar
nmbsun
Default Burping a Radiator?
In the instructions below, how long do you wait between shutting the engine off and opening the radiator cap?
"Here
is the procedure from the shop manual. I repeated it twice on a friends car to
get all the air out:
Start w/ a cold engine
Remove rad. cap
Idle for 1 minute
Install cap
Cycle RPM from idle to 3000
until coolant reaches 210F
Shut off engine
Remove cap
Start engine
Idle for 1 minute
Install cap
Cycle RPM from idle to 3000 until
Shut off engine
Remove cap
Top off"
Old Sep 17, 2010 | 11:17 PM
Rebel 1's Avatar
Rebel 1
I used the same procedure on our '02 and went thru each step without waiting. I Did remove the cap Very Slowly though to let pressure escape.
Old Sep 18, 2010 | 06:47 AM
jdmvette's Avatar
jdmvette
Night Owl for life
good to know.
To Burping a Radiator?
