Help! I have a p0300 code!!!
Old Sep 15, 2010 | 12:36 PM
MyEBc5Z's Avatar
MyEBc5Z
Default Help! I have a p0300 code!!!
So I was driving my car and did a pull from 1st gear to 4th and once I slowed down my rpms stayed at 1200 and once I pulled over and stop, the car started to surge and the idle sounded very slow and weird. Almost like i had a very large cam that was struggling to stay alive. I checked my codes and it threw a 10-PCM P0300 H C and only that. I got the car home and started it the next day....same sound. I know that the code is a random misfire but im going to run a diagnostic on it today to see exactly whats wrong. Has this ever happened to anyone?
Old Sep 15, 2010 | 12:37 PM
MyEBc5Z's Avatar
MyEBc5Z
Oh and mods are LG Longtubes, Halltech Venom, and borla stingers with NO tune.
Old Sep 15, 2010 | 01:03 PM
lucky131969's Avatar
lucky131969
Sure, and if you do a search for P0300, you'll see that. No rocket science here. Pull your codes to see if it will isolate to a cylinder. If not, check plugs and wires(especially since you have headers). A condition of a plug can help isolate a misfiring cylinder as well.
Old Sep 15, 2010 | 01:26 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Absolutely sounds like a misfire---Most scanners will isolate the exact cylinder but I would change ALL the plugs and wires regaurdless
My experience is that people get lulled into thinking that today's spark plugs can go 100K- Maybe---But common sense dictates that even platinum, plugs should be checked every 25-30K miles---ESPECIALLY a modded car with hds/cam/or LT's--
With LT's you could have a wire thats gone bad from being too close to the header tube
My reccmd is to go with the NGK TR55 plugs gapped at .040 and I really like the GM perf(red) wires or the Taylor T-50
LT's open up a whole new can of worms---Short answer is that they make your engine run overly rich during part throttle ans may afect yout WOT fueling as well ---I would a never consider installing LT's without getting a REAL tune---You may even be getting LESS HP or very little unless you tune it--The full potential of your LT's cannot be achieved without a tune---AND its running rich--(could be the reason for your fouling plugs as well----
Old Sep 15, 2010 | 03:33 PM
vettenuts's Avatar
vettenuts
So I was driving my car and did a pull from 1st gear to 4th .....
How many miles on the valve springs and how do you define a "pull"?
Old Sep 15, 2010 | 04:13 PM
dougbfresh's Avatar
dougbfresh
I would also suspect a valve spring bought it here. Pull the valve covers for a "peek".
I believe the code from the DIC will only show P0300, you'll need another scanner to see if there are any p030[1-8] codes.
Old Sep 17, 2010 | 11:41 PM
AZZ-KIKR's Avatar
AZZ-KIKR
I got the exact same code after doing a quick 3rd gear pull to 100 mph, (02 Z with procharger) Once I got into town and started giving it some gas it was running as if it was on 7 cylinders. At idle and revving it a couple times it sounds ok, but under load you can tell something is not right. Suppose I will start looking into it this weekend, starting with plugs, then wires and if that is not it, I'll pull valve covers looking at the springs.. The internals of the engine are all stock and it has around 28K miles on it.. Of which 15K has been under boost..
Fun times.
Old Sep 18, 2010 | 09:15 AM
Lord Vetter's Avatar
Lord Vetter
St. Jude Donor '09-'10-'11-'12-'13
All of the above responses are good ones. I had a similar situation with the P0300 code too. It was a precursor to failed front O2 sensors. Eventually codes P0171 and P0174 would appear with the same symptoms as the original P0300 code. In my case, almost 80K miles with LT headers took its toll on the O2's and they needed to be replaced. Since the replacement of the O2's, no problem at all. Mind you I'm not implying this is the problem with your car but only a passing on of my situation. Good luck with the fix.
Old Sep 18, 2010 | 10:01 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
So your recommendation to the OP is a wholesale replacement of the plugs and wires without performing a visual inspection of the plugs and checking the resistance of the wires, interesting troubleshooting tip.
To Help! I have a p0300 code!!!
