Rear speakers inop
It strange that both speakers are inoperative. That makes me think its at the radio end rather than the speakers end of the circuit. Like dgrant I think I'd start with connectors.
Document ID# 725567
2002 Chevrolet Corvette
Speakers Inoperative - One or More
Step
Action
Value(s)
Yes
No
Schematic Reference: Radio/Audio System Schematics
1
Did you perform the Radio/Audio System Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Radio/Audio System
2
1. Turn ON the ignition, with the engine OFF.
2. Turn ON the radio.
3. Adjust the radio balance and fade to the suspect speaker.
Do all of the speakers operate properly?
Go to Testing for Intermittent and Poor Connections in Wiring Systems
Go to Step 3
3
Are all of the speakers inoperative?
Go to Step 9
Go to Step 4
4
Do both sub-woofer amplified speakers operate properly?
Go to Step 5
Go to Step 11
5
Are all of the non-amplified speakers inoperative?
Go to Step 10
Go to Step 6
6
Test the low level audio signal circuits for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 30
Go to Step 7
7
1. Turn OFF the ignition.
2. Disconnect the radio.
3. Momentarily touch a 1.5 volt battery between the appropriate speaker output circuits of the radio.
Does the speaker emit an audible pop?
Go to Step 21
Go to Step 8
8
Test the appropriate non-amplified speaker output circuits of the radio for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 30
Go to Step 20
9
1. Disconnect the radio.
2. Test the antenna relay coil supply voltage circuit for an open or short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 30
Go to Step 21
10
Test all non-amplified speaker output circuits of the radio for a short to voltage or a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 30
Go to Step 21
11
Are both sub-woofer amplified speakers inoperative?
Go to Step 12
Go to Step 15
12
1. Disconnect the Bose relay.
2. Turn ON the ignition, with the engine OFF.
3. Turn ON the radio.
4. Test the antenna relay coil supply voltage circuit and the battery positive voltage circuit of the Bose relay for an open, high resistance, or a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 30
Go to Step 13
13
Test the ground circuit of the Bose relay for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 30
Go to Step 14
14
2. Place a fused jumper across the Bose relay connections between the battery positive voltage circuit and the speaker supply voltage circuit.
3. Turn ON the ignition, with the engine OFF.
4. Turn ON the radio.
Go to Step 24
Go to Step 23
15
1. Disconnect the appropriate sub-woofer amplifier.
2. Test the speaker supply voltage circuits of the appropriate sub-woofer amplifier for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 30
Go to Step 16
16
Test the ground circuits of the appropriate sub-woofer amplifier for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 30
Go to Step 17
17
1. Adjust the radio volume to an audible level.
2. Test the low level audio signal circuits of the appropriate sub-woofer amplifier for AC voltage.
Does the voltage measure greater than the specified value?
0.20 V AC
Go to Step 22
Go to Step 18
18
Test the low level audio signal circuits of the appropriate sub-woofer amplifier for an open, a short to ground, or for a short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 30
Go to Step 19
19
1. Disconnect the Bose signal processor.
2. Test the appropriate speaker audio input circuits of the Bose signal processor for an open, short to ground, or short to voltage.
Go to Step 30
Go to Step 23
20
Inspect for poor connections at the harness connector of the speaker. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 30
Go to Step 25
21
Inspect for poor connections at the harness connector of the radio. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 30
Go to Step 26
22
Inspect for poor connections at the harness connector of the appropriate sub-woofer. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 30
Go to Step 27
23
Inspect for poor connections at the harness connector of the Bose signal processor. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 30
Go to Step 28
24
Inspect for poor connections at the harness connector of the Bose relay. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 30
Go to Step 29
25
Replace the speaker. Refer to Speaker Replacement - Front or Speaker Replacement - Rear .
Did you complete the replacement?
Go to Step 30
26
Replace the radio. Refer to Radio Replacement .
Did you complete the repair?
Go to Step 30
27
Replace the appropriate sub-woofer amplifier. Refer to Speaker Replacement - Front .
Go to Step 30
28
Replace the Bose signal processor. Refer to Bose Module Replacement .
Go to Step 30
29
Replace the Bose relay.
Go to Step 30
30
Operate the system in order to verify the repair.
System OK
Go to Step 2
