ABS on a 98
Old Sep 19, 2010 | 04:31 AM
3rd_Vette's Avatar
3rd_Vette
Default ABS on a 98
Anyone know when they improved the ABS on the 1998? I know I have read it somewhere here but can't find it. They say "mid year". Mine has a build date of 6/98.. I have yet to look closely under the car, but I have hopes mine falls into the latter of the 1998 builds.
With only 17k miles on my baby, I would hope I wont have any issues for quite some time, even if it has the early version of the ABS..
Tanks in advance!
Notice I spend my nights reading all the forum posts? It's after 1:30 am.. Very addicting!
Old Sep 19, 2010 | 09:13 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
I don't know what VIN number started the later model ABS but it's pretty simple to determine on your car. Raise the hood, stand at the drivers side fender and look down. If you see the ABS module just forward of the alternator it's a late model. No ABS module means it's mounted in the rear and is a early model. I'm not sure it's an improvement because both use the same module on the non Active Handling cars.
Old Sep 19, 2010 | 09:35 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Old Sep 19, 2010 | 11:33 AM
3rd_Vette's Avatar
3rd_Vette
I just went out and looked and it is under the hood! I hope this is a good thing! Thanks
Old Sep 19, 2010 | 12:12 PM
Mark C5's Avatar
Mark C5
Doesn't really matter. They both seem to have the same failure rate and if it goes you're screwed. They can't be repaired and GM does not have any new nor do any vendors. Your only hope is to find a used one at a recyclers or here on the forum from someone parting out a car.
To ABS on a 98
