P0522
Old Sep 20, 2010 | 01:48 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Default P0522
Where is the Oil Pressure Sending unit grounded? Is the ground located on the rear of the head?
Sensor is plugged in, but DIC is showing Oil Pressure XXX
Old Sep 20, 2010 | 01:57 PM
lucky131969's Avatar
lucky131969
It is a discrete circuit, in other words, connected directly to the PCM....all three wires.
If the ground were open, the pressure would read maximum(off scale high). You most likely have a short to voltage. Water getting in the connector will do it, especially for those who have replace the sensor via the "cut a hole" non-method.
