99 headlight problems.....help
Old Sep 22, 2010 | 10:40 PM
lugnuts's Avatar
lugnuts
Default 99 headlight problems.....help
I've already done a search and could not find an answer to my problem...
The headlights won't turn on. The heaqdlight actuator motors don't run and the lamps are off when the switch is turned on. I've already changed the gears to brass in both motors about 2 years ago. The parking lights work fine.
I found 2 fuses under hood that claim to be for the motors and they are hot on both sides.
What I need now is a comprehensive wiring diagram for the headlights, so I can find a common fault for the motors and lamps.
A wiring diagram and any suggestions would be appreciated. Thank you very much.
Charlie
Old Sep 22, 2010 | 10:47 PM
lucky131969's Avatar
lucky131969
Charlie
My suggestion would be to use the search function....come on bro, you've been on the forum for 9 years.
Old Sep 22, 2010 | 11:01 PM
lugnuts's Avatar
lugnuts
"I've already done a search and could not find an answer to my problem..."
I must be a lousy searcher.
Thanks for the comprehensive response and the butt chewing.
Charlie
Old Sep 22, 2010 | 11:11 PM
lucky131969
Charlie
LOL....that's not a butt chewing..... PM sent.
To 99 headlight problems.....help
