1281 Code
Old Sep 23, 2010 | 12:00 AM
Cmike's Avatar
Cmike
Default 1281 Code
Recently replaced ebcm with a used one (only one available). Then I got C1225 code and C1281 code. Cleaned grounds I could find and removed left front wheel and cleaned connections to sensor.Now am getting C1281 code only. Any easy to check before I take it somewhere? Not a mechanic but have managed to fix first two problems from good advice on here. Thanks for this forum
Old Sep 23, 2010 | 12:05 AM
lucky131969's Avatar
lucky131969
Please fill out your sig.....no idea what year you have. Does your car have active handling? aka JL4....
Why did you replace the EBCM to begin with?
Old Sep 23, 2010 | 12:14 AM
Cmike's Avatar
Cmike
Default Ebcm
I have a 2000 convertible and it has active handling.....
Old Sep 23, 2010 | 12:33 AM
lucky131969
Ok..good luck.
Old Sep 23, 2010 | 11:29 PM
gtzy's Avatar
gtzy
Did your replacement EBCM have a M or V on the label?
My 99 JL4 optioned car had an incorrect M version EBCM w/o JL4 installed. It coded 1281 and set SVS lamp.
Installed correct V module and all problems corrected.
http://forums.corvetteforum.com/c5-t...n-98-00-a.html
http://forums.corvetteforum.com/c5-p...ctl-w-jl4.html
http://forums.corvetteforum.com/c5-t...ease-help.html
V=JL4 Active Handling
M= Non Active Handling
Old Sep 23, 2010 | 11:46 PM
Cmike's Avatar
Cmike
Wow....good question....cant answer it though....just felt lucky to even find one and I thought I only needed to know if it had active handling which they said it did when i purchased it from used corvette parts supplier
Old Sep 24, 2010 | 12:01 AM
Cmike's Avatar
Cmike
Default C1251 Code
Bump
Old Sep 24, 2010 | 03:13 PM
BigGun's Avatar
BigGun
Wow...you need to answer the question...could be the problem.
To 1281 Code
