thermostat tuning question
Old Sep 23, 2010 | 11:10 PM
Bullet Proof's Avatar
Bullet Proof
Default thermostat tuning question
changed my thermostat when I replaced the water pump to a vinci 170 degree tstat...from research fans should come on at 194 degrees and turn off at 189 degrees...is this correct? Can you also advance the timing for better performance? If so what does the timing need to be set at?
thanks
Old Sep 23, 2010 | 11:27 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
thanks
You have achieved nothing other than making the engine less heat thermal efficient under part load conditions by performing this work. Under track type conditions on a road or autocross course the engine will operate at much higher temperatures than the range you describe. Any additional timing you would dial in by operating at lower temps serves no purpose under full load track conditions.
Old Sep 24, 2010 | 01:07 AM
00Corvette's Avatar
00Corvette
thanks
You'll have to take the car to a tuner that knows what he's doing man. Buying HP tuners/EFI live is the other way to go if you want to learn to do it yourself.
It's not as simple as just bump the timing..
That's only one of the fans that turns on/off at those temps...the other is on @ 235 off @ 220 I believe..all of it CAN BE adjusted but it's not the type of thing you want to experiment with unless you know what you're doing
Old Sep 24, 2010 | 06:41 AM
99 vett babycar's Avatar
99 vett babycar
Originally Posted by 00Corvette
You'll have to take the car to a tuner that knows what he's doing man...all of it CAN BE adjusted but it's not the type of thing you want to experiment with unless you know what you're doing
To thermostat tuning question
