C5 battery specs
Old Sep 24, 2010 | 01:10 PM
kj217's Avatar
kj217
Default C5 battery specs
time to change the batt,,
what is the factory battery specs??
Old Sep 25, 2010 | 04:45 PM
Dave68's Avatar
Dave68
Of course, these are minimum specs and you certainly don't need an AGM battery.
I'm running the AC Delco Professional 7YR battery (50-month free replacement) but even the Costco Kirkland and Walmart MAXX will do nicely.
Old Sep 25, 2010 | 06:41 PM
Jims79's Avatar
Jims79
any 78 series side post
Old Sep 25, 2010 | 08:51 PM
Sargechris's Avatar
Sargechris
Best place to buy in SD County??
Old Sep 25, 2010 | 08:58 PM
Dave68's Avatar
Dave68
I bought mine through the AC Delco sales rep who stocks Pep Boys stores. They stock AC DElco batteries but not the Professional series (typically, at the dealerships, only). The manager at one of the local Pep Boys hooked me up and I was able to get a decent deal that way.
My second choice would be the Costco Kirkland, as its case is black. The Walmart MAXX is yellow - nice if you have a Millenium Yellow C5, not so nice if you have Magnetic Red as I do.
Old Sep 26, 2010 | 12:50 AM
ZYBORG's Avatar
ZYBORG
I would not buy anything with less than 700 CCA and 110-120 RC as a minimun....
It will help you guard your car against those pesky electrical "gremlins"
Old Sep 26, 2010 | 01:40 AM
Dave68's Avatar
Dave68
Well, during the 7 years I had my 500 CCA OEM battery, I never had any electrical gremlins other than the failed door lock module and column lock actuator (which was definitely not because of low voltage or CCAs.)
That being said, I must mention that the direct replacement battery for my 01 from AC Delco is rated at 700 CCA.
Old Sep 26, 2010 | 10:46 PM
Sargechris's Avatar
Sargechris
Thanks! I'll try at my local Pep Boys...
Old Sep 27, 2010 | 01:43 PM
3rd_Vette's Avatar
3rd_Vette
I have a yellow top Optima that replaced my almost new red top Optima.. No more issues, but next time, Im going with the GM Professional from the dealer. My yellow top doesn't look too bad in my Torch Red C5. It starts the car! Usually always has at least 13 volts so the computer is happy along with 120 reserve Just stay FAR away from the Red Top Optima.. Its under rated for the C5
Old Feb 9, 2011 | 04:23 PM
ONE BMF's Avatar
ONE BMF
The red top is the one recommended for 2004 by Optima on their site. It has way more cranking amps and is what you need to avoid eating starter motors for one. My Red Top (5 yrs old ) has been in since March 2006 and is still fine!The factory battery only made it two years. POS - Look at the specs they speak for themselves or better yet punch up your year and see what they recommend http://www.optimabatteries.com/optim...wtop/index.php
Old Feb 9, 2011 | 05:45 PM
hornet7's Avatar
hornet7
Default Red top
I've have a Red Top for 3 three years now and it's fine.
Old Feb 9, 2011 | 06:48 PM
had2have-it's Avatar
had2have-it
My red top had a short and troubled life...RIP
Old Feb 9, 2011 | 07:42 PM
jrose7004's Avatar
jrose7004
I am on my second Red Top and I believe it's a 34/78.
Old Feb 10, 2011 | 12:35 AM
Oldvetter's Avatar
Oldvetter
I strongly recommend whatever battery you buy, get and use a battery maintainer and use it when your car sits more than 3-4 days.
Old Feb 10, 2011 | 07:39 AM
ShootCraps's Avatar
ShootCraps
The 120 RC is a minimum. I"m using the Maxx from WalMart and it's working great.
Old Feb 10, 2011 | 11:40 AM
ONE BMF's Avatar
ONE BMF
Battery Tender here , won't sulfate battery !
Old Feb 10, 2011 | 01:49 PM
worldtraveler's Avatar
worldtraveler
From: Proud dad of 2 responsible adults and 1 fallen warrior txtx
Stock battery lasted 5 years and my car would routinely sit for 5-6 weeks without a battery tender.
To C5 battery specs
