171 & 174 Code help
Old Sep 25, 2010 | 08:10 PM
Etz's Avatar
Etz
Default 171 & 174 Code help
Can't seem to kick the 171/174 codes. ( both banks running lean) The car runs rough and stumbles from a start. When I unplug the MAF it runs great except for the check engine Light. ( its my understanding that the computer goes to a rich setting when the MAF is unplugged). Cleaned the MAF with the correct cleaner, and even swapped out one with no help. I have looked for a vacuum leaks and haven't turned up anything. Whats next? Check the o2 sensors? How? Anyone had this code, what was the fix?
Old Sep 27, 2010 | 05:12 PM
Etz's Avatar
Etz
Anyone?
Old Sep 28, 2010 | 12:19 AM
canyon lake corvette's Avatar
did you check for vacuum leaks? it will do what you are describing
Old Dec 11, 2010 | 05:56 PM
2004SpiralGrey's Avatar
2004SpiralGrey
Did you ever figure out what the issue was?
Old Dec 11, 2010 | 08:11 PM
Etz's Avatar
Etz
Never found a vacuum leak. Never figured it out.
To 171 & 174 Code help
