FLP Header system finished:WOW!!!
Old Apr 16, 2002 | 11:20 PM
FLP's Avatar
FLP
Default Re: FLP Header system finished:WOW!!! (C5Noir)
Levi,
Only if you are installing from the top, then you have to remove the alternator, coil paks, valve cover and oil filter. From the bottom, none of that is neccessarry.
Dan
FLP
Old Apr 16, 2002 | 11:22 PM
C5Noir's Avatar
C5Noir
Default Re: FLP Header system finished:WOW!!! (FLP)
SWEET! Thanks. Anyone know if TPIS can come out the bottom?
Damn, I could install them in an hour then! YEE HAW!
Old Apr 16, 2002 | 11:45 PM
C5Noir's Avatar
C5Noir
How are ORP's while cruising, any added resonance?
Old Apr 17, 2002 | 12:03 AM
GraveDigger's Avatar
GraveDigger
How much oil did you lose removing hte filter? I'm gonna have to get another quart to replenish mine on Wednesday when install them.
I used about 1/4-1/3 quart, because I did not empty the filter.
Old Apr 17, 2002 | 04:28 PM
360Lemans's Avatar
360Lemans
Default Re: FLP Header system finished:WOW!!! (GraveDigger)
Please, can someone give me a breakdown of the socket sizes and any additional tools required for the FLP install. I will travel about 1 hour for a lift and want to have all the available tools to expedite my install process. I will install from the bottom. What kind of header locking bolts would work with the FLP's? Thanks! :flag
Old Apr 17, 2002 | 05:21 PM
C5Noir's Avatar
C5Noir
Default Re: FLP Header system finished:WOW!!! (360Lemans)
If you're going from the bottom all you need is:
15 mm sockets
13 mm sockets
10 mm sockets for head bolts
7/8 wrench for O2 sensors
The headers come w/new bolts.
