Convertible hatch gone limp
Old Sep 27, 2010 | 12:22 AM
hunterhicks's Avatar
hunterhicks
Default Convertible hatch gone limp
I can't seem to find any mention about replacing the springs/pneumatic shocks that keep the convertible hatch raised when you are raising/lowering the top. Mine won't stay up- it'll just fall when you are trying to maneuver the top.
Anyone dealt with this before? Easy to replace? I assume there are one or two hydraulic shocks tucked away somewhere.
I try not to question the voodoo of the corvette convertible top...
Old Sep 27, 2010 | 01:50 AM
MawneeC5's Avatar
MawneeC5
you need to find a really knowledgeable guy to help you with this. Someone like Mark Martin...
Old Sep 27, 2010 | 02:52 AM
DeeGee's Avatar
DeeGee
Not had to do it myself but looks very straight forward
Document ID# 656600
2002 Chevrolet Corvette
________________________________________
Folding Top Stowage Compartment Lid Struts Replace
Removal Procedure
1. Open the folding top stowage compartment.
2. Remove the forward end of the strut from the hinge ball stud.
3. Close the folding top stowage compartment lid.
4. Open the rear stowage compartment lid.
5. Remove the strut from the rear ball stud.
Installation Procedure
1. Open the rear stowage compartment lid.
2. Position the rod end of the strut through the access hole between the quarter panel and the support.
3. Install the strut to the rear ball stud.
4. Close the rear stowage compartment.
5. Open the folding top stowage compartment.
6. Install the rod end of the strut to the front of the hinge.
7. Close the folding top stowage compartment.
Document ID# 656600
Old Sep 29, 2010 | 12:17 PM
hunterhicks
Awesome- Thanks to Mark Martin and DeeGee I'll be able to keep it up again.
Anyone know that part number/length? (this thread is getting more and more elementary-school yard with everything I say!)
I'm gonna take it off and just see if autozone has a generic one of the same length- that'll probably do it- but if I'm wrong give a shout.
Thanks!
Old Sep 30, 2010 | 10:46 AM
hunterhicks
Alright, these gas struts or gas springs don't seem to exist- anyone had luck finding them? Or have a part number? I've hit up some of the dismantlers looking for some used ones...
Old Sep 30, 2010 | 07:46 PM
Moab's Avatar
Moab
have you tried a truck topper/camper shop? They normally have a good selection of those gas struts kicking around
Jeff
Old Sep 30, 2010 | 08:30 PM
JAY KOCH's Avatar
JAY KOCH
Try Autozone or other auto parts store, they have the gas struts for the trunk on Fixed Roof Coupes (hardtops).
Good luck.
Old Sep 30, 2010 | 10:02 PM
NavyDoc2007's Avatar
NavyDoc2007
I'm having the same problem. Keep us updated on what you find out.
Tim
Old Sep 30, 2010 | 11:48 PM
dmarkshark's Avatar
dmarkshark
I don't see the problem, mine does that, but it only takes a second, and an elbow to move through the whole process?
Old Oct 1, 2010 | 12:03 AM
BobbyG123's Avatar
BobbyG123
Autozone has them (apx 12.00ea.) and its only a 10 minutes job
Old Oct 1, 2010 | 10:48 AM
hunterhicks
I've been to both Autozone and O'Reily's- they have ones that are close... They had one that was really close, but the ends were the wrong size and would not fit on the mounting nubs...
Sooo, I just found someone that had a used set- going for those. Odd that this happened (well, not too odd- this kind of crap happens to my vette all the time!) since there is very little pressure on them.
The only reason I'm replacing them is that every time I raise/lower the top, while holding up the hatch with my elbow/back, the center of the hatch hits the edge of the top- and eventually, that sharp edge will wear down the top. Plus, this is a corvette, not a chevette.
If anyone finds a part number, post it for future reference...
Old Oct 1, 2010 | 11:10 AM
dmarkshark's Avatar
dmarkshark
Check this out.
http://www.zip-corvette.com
Deck Lid Assist Strut M-3485
They have them for $20
Old Oct 1, 2010 | 02:24 PM
BobbyG123's Avatar
BobbyG123
Autozone can order the right ones
I change the hatch and deck lid on my car, they fit fine
Old Nov 11, 2010 | 06:21 PM
Plasticman's Avatar
Plasticman
GM p/n is/was 10275941
I just ordered 2 from ZIP ($49.89 with shipping).
Do not bother putting on used struts, since all struts fail (leak) with age. You will be looking for new ones sooner, than later..........
Plasticman
Old Nov 11, 2010 | 09:34 PM
99 vett babycar's Avatar
99 vett babycar
got mine on that auction site - put your make, model ,year in and they tell you what you need. install is a piece of cake.
Old May 20, 2013 | 04:23 PM
my62toy's Avatar
my62toy
Just bought and installed a pair on my 2003 Convertible. A little tricky getting the clip off the top end of the existing strut but once you get that part done the project is quite simple. Follow the instructions posted earlier.
In terms of where, I got mine off eBay from a supplier called liftsupportsdepot.com. Cost me $29 for the pair, shipped, and they came fast! Best of all: the units I bought are "Made in America"!!! Life is good! Hal
Old May 21, 2013 | 01:44 PM
ALLEGRO's Avatar
ALLEGRO
To Convertible hatch gone limp
