Personally I would be checking it for cleanliness about every 50k miles or so, but that's just me. If you have more blow-by, then clean it or replace it more often.
thanks i just replaced it i have had the car about 2 years i dont know if the one i pulled out was factory or not .I will replace at every oil change they are only 3 bucks.
Good practice....also give you the opportunity to inspect the vacuum line, as that area is prone to breaking/cracking.
That frequency of replacement is WAY overkill! Typically, PCV valves should be replaced when spark plugs are replaced, but considering that our spark plugs can last 100,000 miles, every 50,000 miles for PCV valve changes is reasonable.
Once cleaned, you first verify that the plunger moves freely when you shake it. Then, you blow into it. First from one side then the other. One side should allow the air to go through with very little restriction. When you blow into it from the opposite side, there should be no air getting through. That's it! Simple.
PS: You would be very surprised at how many new aftermarket PCV valves fail this test. Beware, some of them are very cheaply made.
I replaced mine with a late modle LS6 valley cover with the built in PVC and it works so much better to help keep oil out of the intake. Of course a catch helps too.
Like others have said, just clean it with some carb cleaner and blow it out. Make sure it rattles and it's not clogged or sticking.
Is your block an LS6 casting or an LS1 casting?
I've been researching this valley cover upgrade and bought one, but my block is an LS1 casting. Looks like there is some cutting of the block's interior involved, and I'm not comfy doing that to my engine.
I'm curious to know if the newer design LS6 valley cover will fit an LS1 block without all the cutting...
