C5 Headliner
Old Sep 27, 2010 | 11:44 AM
John D. Promer's Avatar
John D. Promer
1st Gear
Default C5 Headliner
Headliner in my 2000 removable top decided to drop down! Any hints on either repairing or replacing?
Thank You
John D. Promer
Old Sep 27, 2010 | 11:55 AM
J T's Avatar
J T
IB Staff
You posted in the Help section, which is used for Help with the website itself (forum issues, account issues, website issues, etc.). You will receive a better response if you post Corvette technical questions in the appropriate Corvette section.
I've moved your thread to the appropriate Corvette section.
Good luck!
Old Sep 27, 2010 | 12:41 PM
runner140*'s Avatar
runner140*
Did mine a couple of weeks ago.
Remove the top and place in a secure, cool spot....and flip (headliner side up).
Pull the headliner out on three sides.
Pull the cork liner up.
Spray the cork top with 3M adhesive spray and let set up...then put the cork backing on the top.
Spray the cork liner with the adhesive, let set up and put down the headliner, use a small roller, pull tight and tuck under the frame.
If you can follow the above, you're a better man than me. P.M. me with any questions.
To C5 Headliner
