Adjusting the mileage?
Old Sep 28, 2010 | 08:32 AM
Nver2loud's Avatar
Nver2loud
Default Adjusting the mileage?
Hey all,
Wonder if someone may be able to help or know someone that can help. I recently had my gauge cluster fail on me, so I bought a used cluster to replace it. The problem I am having is that the new cluster has ALOT less miles than my car has, and I really want to get it set to the current mileage. If it were a matter of a few thousand miles I would not worry about it, but its like 80k miles. My local dealer which is pretty large told me they do not have the equipment to change the mileage and I would have to send out the cluster to specmo at the tune of $450. I'm located in Madison, WI and willing to travel if someone knows someone that can get this done, preferably on the cheap.
Thanks everyone!
Old Sep 29, 2010 | 08:47 AM
Nver2loud's Avatar
Nver2loud
Anybody?
Old Sep 30, 2010 | 10:25 AM
Nver2loud's Avatar
Nver2loud
Nobody has ever needed their mileage adjusted from a cluster swap??
Old Sep 30, 2010 | 10:46 AM
lucky131969's Avatar
lucky131969
I think most have just been swapping the PCB's out, so the mileage transfers.
Old Sep 30, 2010 | 12:56 PM
Nver2loud's Avatar
Nver2loud
My problem was the speaker driver within the PCB though
Old Sep 30, 2010 | 01:02 PM
lucky131969
Just curious, have you swapped out the IPC to make sure the noise goes away?
Bill Dearborn's Avatar
Bill Dearborn
Who gave you the $450 cost? Is that Specmo's estimate or somebody elses? Have you tried a different dealer?
Bill
Old Sep 30, 2010 | 01:06 PM
Nver2loud's Avatar
Nver2loud
Yeah, the new cluster is in, noise is gone thank god. Cluster is just like 80k off. I havent called any other dealers as this was really the only one in my area that is a large chevy dealer and figured they would know best. $450 was the dealers estimate for the cost.
Old Sep 30, 2010 | 01:22 PM
lucky131969
Give these guys a call, make sure you have the P/N for both IPCs when you call.
Advanced Electronics Remanufacturing (AER)
650 Columbia Street
Brea
CA 92821
800-321-6970
www.aertech.com
Old Sep 30, 2010 | 02:26 PM
Nver2loud's Avatar
Nver2loud
Wow, thanks for the info! I may actually be able to use this for work as well. Whats not good is that I dont have the numbers off the ipc so i will have to pull the cluster out...again. This will be time number 4.
To Adjusting the mileage?
