Help with engine grounds on engine build
Old Sep 29, 2010 | 07:02 PM
Pwrtrip75's Avatar
Pwrtrip75
Default Help with engine grounds on engine build
Rebuilt my engine. Put it back in. Barely wanted to start, runs 5 seconds then dies like its out of gas. Got these codes.
(convenience) U1064 - Loss of communication to the DIM
(convenience) U1096 - Loss of communication to the IPC
(restraints) B1001 - Option configuration error
(Brake) C1278 TCS Temporarily inhibited by PCM
(PCM) P0443 Evap solenoid valve 1
(PCM) PO803 1-4 upshift malfuntion
Found on LS1tech another guy who had the same problems and everyone said check his ground on back of engine.
Ok, I didnt hook the bracket up to the bellhousing and I dont know what ones im missing,....if any.....??
(also had to take heads off cause they were 852 castings and I used MLS gaskets = leak around the notch on the head....grrrr....anyway..)
Here is a pic of the current grounds... Am I missing any? And also the small black wire that comes out of the starter harness.... is that a ground or should that go to the POS on the starter? Its hard to see in the pic but I have it hooked up to ground.
this one I did initially forget to hook up and the car wouldnt start, I did have it hooked up after.
Old Sep 29, 2010 | 07:09 PM
lucky131969's Avatar
lucky131969
PM sent....call me.
Old Sep 29, 2010 | 07:19 PM
lucky131969
Also, it looks like you are missing a ground terminal at G105, which provides a ground (via SP122) for the fuel pump relay, O2's, and oil level sensor.
http://forums.corvetteforum.com/c5-t...e-grounds.html
Old Sep 29, 2010 | 07:44 PM
Pwrtrip75's Avatar
Pwrtrip75
Originally Posted by lucky131969
PM sent....call me.
Thanks for the help.
Once i get it back together and fix the broken ground for the fuel pump relay in back i hope it runs
To Help with engine grounds on engine build
