Cam install question?
Old Sep 29, 2010 | 10:01 PM
RogerT's Avatar
RogerT
Default Cam install question?
I was just told that the engine needs to be removed to install a new camshaft. I do not think it does, but I really do not know. Experts input please.
Roger T
Old Sep 29, 2010 | 10:07 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Nope, just the radiator and ac condenser
Old Sep 29, 2010 | 10:11 PM
Jnape's Avatar
Jnape
And harmonic balancer (unless you have a split cover) so the power steering rack has to be moved to the side.
Old Sep 29, 2010 | 10:23 PM
slvrzo6's Avatar
slvrzo6
I'm having a New cam installed right now by Finish Line Performance. And the others are correct. Your engine stays put, but the Air Cleaner, Air Bridge, Radiator and Harmonic Balancer need to come out! The power Steer Rack needs to be loosened and moved to the side. You will need though. New valve Springs, Timing Chain, Retainers, Seals and Pushrods Plus You'll need a new Tune.. Thus why FLP is doing mine.
Old Sep 30, 2010 | 12:52 AM
TGstring's Avatar
TGstring
From: cruising between USA and Canada... SAVE THE WAVE!
the only thing that needs to be physically removed out of the car is the airbox and radiator.
the condenser can remain intact- just moved out of the way...as well as the steering rack which needs to be moved out of the way.
HTH,
TGstring
Old Sep 30, 2010 | 01:23 AM
bdiddo's Avatar
bdiddo
HTH,
TGstring
yeah..what he said
Old Sep 30, 2010 | 08:00 PM
zeevette's Avatar
zeevette
I thought it was a difficult job, until I installed a new clutch.
Old Sep 30, 2010 | 08:06 PM
Paul 75 L82's Avatar
Paul 75 L82
Old Sep 30, 2010 | 09:58 PM
corvette8189's Avatar
corvette8189
HTH,
TGstring
easy job
follow this link and get it done, skip the parts about the heads
http://ls1howto.com/index.php?article=1
Old Sep 30, 2010 | 10:19 PM
RogerT's Avatar
RogerT
Default Thank you !
Thank you to all who replied to my camshaft installation question.
Roger T
Old Oct 1, 2010 | 01:59 PM
Too-Fast's Avatar
Too-Fast
Active Streak: 90 Days
2024 C6 of the Year Winner - Modified
If I may ask, what is the cost for a complete change like that and what kind of HP increase do you expect?
To Cam install question?
