Thermostat change time
Old Sep 30, 2010 | 08:21 PM
rried2tall's Avatar
rried2tall
Default Thermostat change time
Hi Guys
I'm changing my therm soon and wondered if any of you have had trouble with after market thermosats, should I stay with GM parts and what temperature therm should I get? If I go with the 180 degree I know I should reprogram the PCM for the full affect.
Thanks Ron
Old Sep 30, 2010 | 08:43 PM
CARRJET's Avatar
CARRJET
Hi, I changed mine last month along with a radiator change for a leak in plastic side tank. I used one (stock temp) from auto zone with no problems.
Old Sep 30, 2010 | 09:33 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Why are you changing the thermostat ?
Old Sep 30, 2010 | 09:39 PM
rried2tall's Avatar
rried2tall
Default therm change
I'm changing because I had it get hot on a ride, came home to find fans not running, think I have that fixed. just feel like I would like to put in fresh atifreez and new therm to be sure all is ok, car has 56000 miles on it.
Ron
Old Sep 30, 2010 | 10:11 PM
Evil-Twin's Avatar
Evil-Twin
Ron
What do you consider a hot ride?
If the stat is ok via a simple test why replace it?
Just throw it in some water with a meat thermometer , ( which is something you should do with a New stat as well ) as it approaches the designed setting you should be able to note its opening. The New antifreeze is a good idea.. 2 gallons of antifreeze is nothing. I know guys with 200,000 miles on their C5 with the same original stat. I am not trying to talk you out of anything.. Many people like to change things just for the sake of change.
Old Sep 30, 2010 | 10:18 PM
CBackous's Avatar
CBackous
Hi Guys
Thanks Ron
180 is the factory temp, so you shouldnt need to reprogram anything.
Old Sep 30, 2010 | 11:02 PM
Evil-Twin's Avatar
Evil-Twin
It is???? that's news to me !
Old Oct 1, 2010 | 01:33 PM
CBackous's Avatar
CBackous
I stand corrected.
Old Oct 1, 2010 | 01:54 PM
Rebel 1's Avatar
Rebel 1
Stock stat is 187*.....
Old Oct 1, 2010 | 06:37 PM
rried2tall's Avatar
rried2tall
Default 180 factory therm
Hi Guys
I removed the them today and I'm pretty sure it is the factory unit, it has 100c on it, checking my conversion tables that would be 212F. Now the question is does GM sell a 180F therm or do I need to buy an after market therm.
There is a big price difference between the two.
Ron
Old Oct 1, 2010 | 08:29 PM
vettenuts's Avatar
vettenuts
Your stock thermostat is easily modified to open at lower temps and the total cost is about $1. Why spend all that money.
Old Oct 1, 2010 | 10:18 PM
rried2tall's Avatar
rried2tall
Default Them change
I like to save money like the next guy but with something so important and aftermarket therms are only about $35 bucks why not go for the reliablity. How do you modify a therm, and then make sure it opens where you want it to, that sounds like a little testing and adjusting to get it right.
Ron
Old Oct 2, 2010 | 08:05 AM
vettenuts's Avatar
vettenuts
Ron
Here you go, I ended up using the thinnest shim and mine opens at a little less then 180. If I ever take it out again I plan to reduce the shim to 0.050". Link
Old Oct 2, 2010 | 02:44 PM
rried2tall's Avatar
rried2tall
Default Thanks for all the great info
Thanks for the info. now I'm thinking I really should test mine and change the therm as you discrib. did you notice any reduced mileage with the lower temp. I'm thinking of a manual fan operation also, I want to turn on fans when I want to.
thanks Ron
Old Oct 2, 2010 | 07:39 PM
vettenuts's Avatar
vettenuts
Hard to tell, I did it with a head/cam installation so mileage wasn't much of a concern.
Old Oct 3, 2010 | 03:58 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Ron
check that your low speed (drivers) fan is not broken.
reach into the fan shroud on a cold engine and try to spin the blades.
Old Oct 3, 2010 | 07:00 AM
LS7.2's Avatar
LS7.2
1st. check for any leak from water pump, hoses, radiater.
2nd. go for 160 aftermarket stat.
Let your engine run coooler
To Thermostat change time
Old Oct 4, 2010 | 04:55 PM
rried2tall's Avatar
rried2tall
Default All Done
After checking fan grounds and cleaning them up as they measured 2 ohms of resistance, checking the thermostat several times and refilling with new Dex Cool everything seems fine.
I was thinking of buying a new therm but found most where made in China, Mexico or other foriegn countrys I decided to stay with the original as it works fine and is 7years old and might be made in the USA.
It sure bugs me that so much stuff is made some where else, I purchased a Bra for the vette and it was made in China and doesn't fit that great.
Owe well the car cooling system seems fine so that's good, Ron
Old Oct 4, 2010 | 07:51 PM
vettenuts's Avatar
vettenuts
One nice thing about modding the GM stat, it is quickly un-modded as well and the quality is very good.
Old Oct 4, 2010 | 09:05 PM
87gtNOS's Avatar
87gtNOS
time to install.....5mins.
