Thanks for the diagram! One last, would you have the one that shows the wires from there to either the ignition switch, the driver's door or maybe directly to the IPC?? Or I wouldnt mine even paying for it if it's available.
I removed the hole dash and cluster to make sure everything was properly plug and tight. I even cleaned the IPC connections. The car has the HUD from factory.
You can order ANY Corvette Service manual set from Gene Culley.
His site is www.gmpartshouse.com. The paper back books are a thick 3 volume set and each set is year specific and I believe there approx $110. for the set.
