Broken Head Bolt
Old Apr 1, 2002 | 12:16 AM
VinR1's Avatar
VinR1
Default Broken Head Bolt
wow, its been a while since ive been on here! Installing a head/cam package on my buddies '98 and the town moron snapped a head bolt off while removing the factory head. The remaining piece of the bolt seems to be about two inches below the surface of the block - can we drill it out like a normal bolt or is there any precautions/extra measures we need to take in order to protect the aluminum?
...I really wanna avoid pulling the block and taking it to the machine shop
any ideas?
[Modified by Vince383, 10:46 PM 3/31/2002]
Old Apr 1, 2002 | 12:40 AM
MDT's Avatar
MDT
Default Re: Broken Head Bolt (Vince383)
Vince383,
Years ago, I helped a friend find the source of the "rattle" in his flat head Ford engine. (I said it was years ago.)
Anyway, we found a valve seat had loosened in the block and was rattling around on the valve stem. We got a guy from a local machine shop to come out on a house call...he brought the necessary tools to cut the block for an over size valve seat, hammered it in, lapped the valve and we were good to go. Only took him about 30 minutes. The charge was nominal.
Doubt seriouslythat you will find someone these days to do something like that, so there is a real possibility that you may have to tackle it yourself.
Good luck.
Mark
Old Apr 1, 2002 | 01:41 AM
alc2001's Avatar
alc2001
This is bad, as if you didn't already know that. That it broke during removal means the threads are seized which dims the prospect that you could drill into the bolt and use an ezout. The service manual has a procedure for repairing the threads. There is a special kit with a guide plate, threaded inserts and other various pieces. The procedure makes no mention of what to do if the bolt is stuck in the block. I would try the ezout (extractor) first, machine shop if all else fails. Good luck.
ps The M11 head bolts are not reusable (10 per head).
[Modified by alc2001, 9:47 PM 3/31/2002]
Old Apr 1, 2002 | 07:53 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Soak the remaining bolt in PB BLASTER. It is a good rust/corrosion blaster.
As long as the fastenerr was not cross threaded at assembly, there is a good chance after an overnight soak you can drill it & ez-out it. Use Ti coated drills. This will help start the center hole you drill and keep it from wandering off center. Start with as small a drill bit as you can. Centering the hole is important for the ez-out to grip evenly.
Good luck.................AND TAKE YOUR TIME!
Old Apr 7, 2002 | 03:51 PM
MelloYellow's Avatar
MelloYellow
Default Re: Broken Head Bolt (ALLTHROTTLE&NOBOTTLE)
1998's have a TSB for improperly machined heads or something. If your VIN matches you may be able to get a new engine. Lemme try to find the thread...
Looks like it's for an exhaust leak tho. Addresses the head more than the block threads. Worth a try maybe?
Here: http://www.ls1tech.com/ubb/cgi-bin/u...c;f=1;t=004336
[Modified by MelloYellow, 2:52 PM 4/7/2002]
Old Apr 7, 2002 | 04:27 PM
C5 Hardtop's Avatar
C5 Hardtop
While learing my lesson on FT- LBS vs. IN-LBS, I snapped a bolt on a manifold. I didn't touch it, just took it to a machine shop. I picked it up a few hours later and the bolt was out for $20. They said I did the right thing by not messing with it before taking it to them. If you fail, then try to take it to a machine shop, it will be harder for them.
I would tow the car to a machine shop and have them do it.
Joel
Old Apr 7, 2002 | 05:06 PM
wwashing's Avatar
wwashing
Default Re: Broken Head Bolt (MelloYellow)
This TSB is for SPARK PLUG ports not HEAD BOLT holes! :nono:
Old Apr 8, 2002 | 04:45 AM
MelloYellow
Default Re: Broken Head Bolt (wwashing)
Ya.. guess they would only replace the heads..
Old Apr 8, 2002 | 06:40 AM
vettenuts's Avatar
vettenuts
I have done a lot of work on outboard motors. It is very difficult to remove a broken bolt from aluminum without the proper tools and jigs. Personally, I would talk to a machine shop and if they have the equipment I would flat bed it in. You don't want to be removing the block for the "other" reason. Good luck, hope it turns out OK.
To Broken Head Bolt
