I thought I post some pictures of the RPM's polyurethane couplers while I was installing these on a 99 torque tube. These are a better option than using the billet aluminum couplers IMHO. Take a look.
Those look way higher quality than the BMW ones being recommended years ago. I tried those....Kablooey! all over the highway
Those poly's do look nice..however my OEM bushings said "made in Germany" just the same as the BMW units that went in and replaced them. lasted for 125K for me..
The poly's are definitely the way to go though in my opinion if you're all the way in there already.
I didn't realize that poly's were available and thought the only option was rubber or aluminum
Yea, thats all we had 5 years ago. In the poor bushings defense....i was making 650Rwhp.
Yeah, this is on RPM's website under "new products". I haven't put this in the car yet but I'll post the first drive impressions when I get to drive it. Click below for the details.
For the price, I would stick with stock units. For what it's worth, they are propshaft couplings, not torque tube couplings. The torque tube is the stationery tube that the propshaft and couplings rotate in.
These have been around for a while, but I haven't seen any feedback...
I have a set of the 10mm couplers and I think the driveshaft
kind of feels tighter. Probably the combination of the Yank
stall and the FLT tranny all combined together. I run alot
of horsepower and I am more confident with the RPM couplers
instead of the stock couplers. The price of $375 is not cheap
but you can see the quality.
The later cars had the larger 10mm version right? Are there many failures w these?
I think I would try the Zip version for less than half the price before the other.
How is it less the 1/2 the price, the Zip couplers are $149.00 EA.
The RPM couplers are $375.00 per pair.
FWIW, the later cars come with 12mm bolts the only difference is is the bolt and the bolt hole through the coupler.
I see, thought it was for a pair.
I thought the 12mm was the thickness of the base.
Didn't they change this due to the problems? Doesn't the larger hole disperse the stress more evenly, and makes it harder to push a large object through something (rubber) than a smaller one?
The later tubes also have a thicker shaft... 63mm VS 55 mm.
