head lights stay open
Old Oct 3, 2010 | 11:33 AM
paulcantin's Avatar
paulcantin
Default head lights stay open
No instrument lights - headlights stay up -1998 Coupe
Old Oct 3, 2010 | 12:24 PM
lucky131969's Avatar
lucky131969
check minifuse #6 in the passenger footwell.
Old Oct 3, 2010 | 01:37 PM
paulcantin's Avatar
paulcantin
Owners manual (from a 2004 Corvette) defines fuse #6 as Parking lamps, Taillamps
Old Oct 3, 2010 | 02:14 PM
byronhunter's Avatar
byronhunter
So--have you checked it? Is it good? If it's good, next to check is the Multifunction Switch.
Old Oct 3, 2010 | 02:28 PM
byronhunter
Old Oct 3, 2010 | 02:36 PM
paulcantin's Avatar
paulcantin
Fuse looks O.K
No break in filiment.
Multi function switch replaced 6,000 miles ago as a result of headlights not comming up.
Is there any significance to the dash lights not working?
Courtesy lights -running lights -head lights - directionals are all working
Old Oct 3, 2010 | 02:40 PM
paulcantin's Avatar
paulcantin
Thanks for the diagram but way beyond my capability.
Old Oct 3, 2010 | 03:16 PM
lucky131969
Fuse looks O.K
Yep, and the above schematic is not correct for a 98.
Old Oct 3, 2010 | 03:23 PM
lucky131969
Well, if you are absolutely sure that minifuse #6 is good, then you'll have to take voltage measurements with a meter. The easiest would be at minifuse #6, and then the headlamp door control module, pin C(dark green wire).
Old Oct 3, 2010 | 03:36 PM
paulcantin's Avatar
paulcantin
Thanks for the correct diagram.
Don't know a good fuse from a bad one - so it will go to the tech. tomorrow and I'll do what I know best---write a check then use my time to make another sale.
I appreciate your help.
Old Oct 3, 2010 | 03:38 PM
lucky131969
Don't know a good fuse from a bad one - so it will go to the tech. tomorrow and I'll do wat I know best---write a check then use my time to make another sale.
Your choice.....but you could always just replace the fuse...there are spares in both fuse boxes.
Good luck.
byronhunter
You keep me straight, ok? He said he was looking at '04 Manual. I should have gone back and read the 1st post again. I can alwaya depend on you.
Old Oct 3, 2010 | 03:41 PM
lucky131969
No biggie, basically they are the same, and minifuse #6 serves the same function.......except no twilight sentinel ....so the relays are different.....
Old Oct 3, 2010 | 07:26 PM
paulcantin's Avatar
paulcantin
Replaced fuse - no change - front running lights - front hazards - headlights - directionals are O.K. -
No dash lights -message center lights up - interior lights work.
Only the third light and the back up lights work in the rear.
Head lights will not retract.
To head lights stay open
