I Need help
I have a 2002 C-5 Corvette. I has been sitting in my garage without being started since May 2008. That’s 2 years 4 months.
Besides the battery going bad , which I replaced since charging didn’t seem to help.
The car starts right up, oil pressure 40PSI @ idle. But the idle is very rough. Have to keep foot on gas to keep running until temp is at least 100 degrees. Put fresh gallon of high test with a can of Techron. Idle improved somewhat.
Car is occasionally back firing through the exhaust. Took it out for test ride and to burn through the bad gas from sitting too long.
And back firing got worse. While sitting in my garage car backfired through exhaust again and blew ceramic honey comb out the exhaust from one of the cats. Exhaust smells bad now. Blown out ceramic pieces and what looks like very small pieces of a cotton shop towel laying on the ground under the right side exhaust pipe. But those pieces of what looks like a shop towel are very white not burnt. I don’t remember if I put a rag in the intake so nothing got in there and forgot to remove it before I put the air intake back on. Additional info, Kooks headers and Borla XR-1 exhaust. The resonator has an X pipe inside of it, no mufflers.
did it look like this? http://www.youtube.com/watch?v=tDvmjk6LHYU
The video link you posted, was right on, That's exactly what happened. Only just one bang everything else the same!
Have added one can of Heet and one can of fuel injection cleaner to fuel tank.
Let it sit overnight.
The idle has really smoothed out, no backfireing on startup.
Hand on shifter when idling, still vibration but less than half of what it was.
Engine was always rock solid.
The reason I said it may have swallowed a rag was because of the crap on the ground mixed with the ceramic pieces from the cat. Now I'm not so sure, maybe what looks like white cotton is part of the blown out cat?
Been idling for 25 minutes a day, car gets smoother each time.
Still blowing some crap out of right exhaust on ground. So more pieces of cat still in exhause I can hear then rattling aroung inside of the pipe.
I think I am going to bite the bullet and jump the fuel pump and drain the gas that way.
Trying to drain the gas by idling is not working, I still have just a tad over a half tank.
But my gas gauge was reading a little over half tank last night.
Now the car will not start? It makes slight attemptto start then slight backfire? Acts like its out of Gas! But like I said I got 1.6 gallons out and the gauge read a little over 1/2 tank last night??
Could the remaining gas be in the passengers side tank?
Or does the fuel system ballance itself out automatically, transferring gas from one tank to the other automatically?
If so, how do I get the remaining fuel to the other side?
Maybe my gas gauge was reading wrong in the first place. I do have that problem at times thas why I use techron.
If the gas is all out then I would like to refill and add sea foam.
I have had my hands on several cars that sat for years and although the gas is not much good, if you add some octane booster and drive the crap outta it on the highway it will "eventually" smooth things out.
Letting an engine sit is not the greatest thing one can do.
I dont know exactly how it sounds or whats going on, but if it were me I'd bolt it all back together, replace, disconnect, or remove the cats, and drive it in 4th or 5th gear on the highway for a good bit (or D if its and auto), with occasional full throttle accels.
Oh, idling is not great for it either, just drive it. If something breaks you'll know what was wrong so you can fix it
Peter
Next day,
I pulled all the plugs and checked all of them. 1,3,5,7, all look great.
2,4,6,8 not so good! They were all sooted up, and wet with gas (Still wet from last night),
So at this time I don't think it's the Gas being bad.
Wrong call on my part from the beginning.
It appears that either the injectors for 2,4,6, and 8 are dumping huge amounts of fuel With each cycle and foul the plugs. ( Could be, but I doubt it)
Or
Cylinders 2,4,6, & 8 are intermittently firing. Fowling the plugs and allowing a huge amount of unburnt gas to accumulate on the right side Catalytic converter honeycomb, then, after the cylinder does fire, the explosion causes the gas in the cat to go boom and shoot pieces out the exhaust.
What do you think?
Car will idle smoothly now.
But giving it gas starts the backfiring through the right side exhaust again.
The only thing that was changed was that both coil pack harness was retaped after the old tape was removed. Last year some time. ( Now’s not the time for anger and harsh words)
I removed new tubing and tape, all the way back down to wires. One wire had a small skinned area but that was taped over before the harness was retaped. Other than that I can’t see any skinned areas. Coils don’t go suddenly bad in packs of 4, all on one side? New MSD wire set.
How do you check the coil harness for shorts ?
I’m open
Codes?
Sounds like time to get a scanner on it and read the O2 signal and PWM duty cycle of the injectors to get some hint. Also, get a test light to check if there is a consistant spark or not on those cylinders (you can clip a timing light to each wire and see if it flashes consistantly or not). You can also pull the injector rail set and then cycle the pump on and see if any leak fuel. It's not likely that 4 on one side are leaking and the other 4 are good though. to me, sounds like Feeder is correct and the main O2 on that side is bad and giving a false lean signal.
since you did mes with that wiring harness then check the connectors over to see if there is a problem you caused there, such as pulling a wire or pin out of the connector.
Peter
So now I believe it is not the fuel system, or the gas.
The whole bank is not firing correctly?? Cyl 2,4,6, and 8 are firing intermittintly or firing out of the correct order??
Let me ask a stupid question at this point.
Does anybody know what would happen if you connected the coil harness in reverse ? In other words, If #2 cyl was being fired by #8 in the harness instead of #2 ?
I 'm trying to take your reply as serious, but I'm looking at your avatar of a dog whith a human face on it. Work with me here.
Do you have actual experience with these motors or are you guessing.
Like I stated I do not want to offend you, just confirming the information as accurate before I have to take the harness apart, to test, I know you can understand that.
