clunk in drivetrain
Old Oct 4, 2010 | 12:31 PM
oltimerocknroll's Avatar
oltimerocknroll
3rd Gear
Default clunk in drivetrain
I have a 2003 6 speed that has a noticeable "clunk" in the drive train when I go from reverse to 1st gear or vice versa. It also happens is 1st gear, when moving at a slow speed and letting off the gas, or accelerating. The local dealership says this is normal, and there is a service bulletin out on this same thing. Has anyone else had this same problem with a 2003? I can't believe this is normal.
Old Oct 4, 2010 | 12:52 PM
LoneStarFRC's Avatar
LoneStarFRC
No, it's NOT normal. Based on what you're saying, I would suspect one, or both, drive shaft couplers.
Old Oct 4, 2010 | 02:23 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Definitely not normal ! About all you can do is get the car on a lift and start checking every part of the suspension and driveline. Check for worn A arm bushings, torque on all fasteners, sway bar bushings, shock bushings, etc. Check CV joints on each axle. Check motor, tranny and differential mounts. If all that is OK, it might be the drive shaft bushings. Dealer tech is full of they were not willing to spend the time to properly diagnose the problem, it cound take a couple of hours time to go through everything properly.
Old Oct 4, 2010 | 02:55 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
How many miles on this car? Do you feel it, hear it, or both?
Old Oct 4, 2010 | 09:45 PM
MNCrystalRed2011's Avatar
MNCrystalRed2011
Check the torque on the rear axle spindle nuts. The nut is a 34mm (you will need a deep socket) and the torque spec is 118lbs/ft.
Old Oct 4, 2010 | 09:54 PM
oltimerocknroll
3rd Gear
The car only has 22,000 miles on it. I can both feel and hear the clunk. It feels like slop somewhere in the drive train
Old Oct 4, 2010 | 10:06 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
It may be the differential check the fluid.
Old Oct 5, 2010 | 08:36 AM
Eric D's Avatar
Eric D
The most likely things it could be:
  • As mentioned in the earlier post, loose axle shaft retainer nut.
  • Bad output shaft constant velocity joint or joints.
  • Not very likely, but something in the differential.
What it isn’t likely to be:
  • Propshaft couplers, the propshaft on the automatic is rotating any time the engine is running.
Old Oct 5, 2010 | 09:34 AM
oltimerocknroll
3rd Gear
Thanks for your help. I'll be checking things out myself. It seems the dealerships aren't interested in getting to the root of the problem.
Old Oct 5, 2010 | 12:10 PM
jjsigns's Avatar
jjsigns
I had a similar "clunk" on my 2000 Vette. It sounded external. Everything checked out ok on the drivetrain. It ended up being the plastic mounts on the rear sway bar. Cheap fix. ( $30 bucks each at O'Reileys - plus they are the updated all metal ones)
Old Oct 5, 2010 | 01:59 PM
92mr2turbo's Avatar
92mr2turbo
got pics?
To clunk in drivetrain
